Code P0650, abs, service soon. Suggestions?
Old Jan 26, 2010 | 07:23 PM
ls1forlife's Avatar
ls1forlife
Default Code P0650, abs, service soon. Suggestions?
my 02 z06's service soon came on,service abs, as well as ah and tc off. i turned it off and it was fine for about 30 miles, then it came on again. i scanned it and it was p0650 twice. any ideas? car has 30k miles. all stock, nothing done but a slp exhaust.
the code is indicator light? MIL..doesnt really tell me much though
thanks a lot everyone!
Old Jan 26, 2010 | 08:12 PM
lucky131969's Avatar
lucky131969
What are all the codes? You must have more if you are getting a service abs/tc warning.
Old Jan 27, 2010 | 10:51 AM
ls1forlife's Avatar
ls1forlife
P0650 twice. thats all...
thank you
Old Jan 27, 2010 | 12:07 PM
87SAM's Avatar
87SAM
What are you using to look for codes, the DIC or a aftermarket code reader?
As far as the P0650, you got that info in the other thread.
Old Jan 27, 2010 | 01:36 PM
trussme's Avatar
trussme
Default Code PO650
Something is wrong with your check engine light.
voltage is supplied directly to the Malfunction Indicator Lamp (MIL) . The PCM controls the lamp by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line which is monitored by the PCM. When the PCM is commanding a component ON, the voltage of the control circuit should be low (near 0 volts ). When the PCM is commanding the control circuit to a component OFF, the voltage potential of the circuit should be high (near battery voltage). If the fault detection circuit senses a voltage other than what is expected, the fault line status will change causing the DTC to set.
The PCM also communicates with the EBCM & this may be why the other ( service abs,t/c & a/h) warnings are indicated... battery terminals tighten to spec? ..........checked all grounds? defective EBCM?
Old Jan 27, 2010 | 03:19 PM
ls1forlife's Avatar
ls1forlife
I took it to autozone and used their tool, it was displayed like this:
P0650
P0650
no other codes.
but like i said the ah, tc, and abs came on twice about 50 miles ago. have not came on since. and went right off after i shut off and restarted the car...
thanks for all your input.
my cel comes on with the ignition, so i think it works fine.
Old Jan 27, 2010 | 03:24 PM
87SAM's Avatar
87SAM
Use the DIC to check for codes.
http://www.c5forum.com/ayc/dtcdic.php
Old Jan 27, 2010 | 05:56 PM
ls1forlife's Avatar
ls1forlife
correction, cel does not come on when ignition is on. but it came on when the service soon came on. but then i shut the car off and restarted it. and it was fine, then it did it about 20 miles later. after i shut the car off that time it hasnt happened in over 100 miles? wtf?
Old Jan 27, 2010 | 05:59 PM
lucky131969
You can't fix it if it's not broke. Post back up if it happens again.
Old Jan 28, 2010 | 10:04 AM
ls1forlife's Avatar
ls1forlife
great! well im about 100 miles since anything popped on. so ill hope for the best. it was also like 30 degrees, i dont know if that had a direct effect on anything or not. goes for PA inspection tuesday. maybe ill ask my mechanic, he knows c5s and fbodies in and out.
thanks again everyone!
To Code P0650, abs, service soon. Suggestions?
