FAST install
Old Jan 28, 2010 | 05:08 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default FAST install
Is there any benifit to relocating MAP to front on FAST intake?
Old Jan 28, 2010 | 05:20 PM
chevy406's Avatar
chevy406
There is no performance benefit to relocating the MAF. The only reason to move it to the front is if you are having trouble sealing it at the back. Once you get it properly sealed there isn't any further reason to mess with it. I tried relocating mine, and it led to more problems with vacuum leaks. It's back in the rear of the intake now, and I haven't touched it since.
Old Jan 28, 2010 | 06:51 PM
vettenuts's Avatar
vettenuts
Some have had problems with it hitting the cowl. I relocated mine but it is still in the back. Next time it is off I plan to install the LPE kit. Much cleaner installation.
Old Jan 28, 2010 | 10:53 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
I have things ready to install and seen some have done the relocate. I didn't see an advantage but thought I'd see if I missed something some where.
Old Jan 29, 2010 | 07:36 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I relocated mine after I tuned a guys car and noticed his was relocated right in front of the throttle body. I liked the theory behind the relocation, but noticed no change. I did it only because it seem to make sense that the MAF take its most exact reading just before the air enters the motor.
Old Jan 29, 2010 | 07:39 AM
phils C5 vette
I purchased the extra couplers at home deport in the pumbing section where they sell the 4 inch waste piping.
Old Jan 29, 2010 | 07:44 AM
phils C5 vette
you can also see where I relocated the IAT sensor into the head of the Vararam cover. I did this before I learned more about tuning. Now, I would not relocate the IAT because I can adjust the IAT sensor tables for less Knock Retard with HP Tuners.
Old Jan 29, 2010 | 09:35 AM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
In the event I have a leak problem where are y'all getting the relocating piece from besides LPE.
Old Jan 29, 2010 | 01:07 PM
phils C5 vette
I think that's where I got mine. ( if your talking about the MAP sensor)
Old Jan 29, 2010 | 02:45 PM
phils C5 vette
My bad. I thought you wanted to relocate the MAF. lol
But you can see I also relocated the MAP so it didnt make contact with the firewall
Old Jan 29, 2010 | 06:22 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Where did you get the peice from to relocate MAP?
Old Jan 29, 2010 | 06:26 PM
phils C5 vette
LPE i think
it was like $60
Old Jan 29, 2010 | 07:33 PM
sami85L98's Avatar
sami85L98
Phil is right and so others, you can also buy from katech or caspers electronics, i bought from caspers same thing what lpe sells well if not same than it will be close. I did in the rear but did L shape plumbing called elbow.
Old Jan 30, 2010 | 11:04 AM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
I know where to get the wire harness for LS6 TB to LS2TB and the extention for MAP to front. What I need is info for the plug and retainer that goes to top of manifold what instructions sheet shows to install EGR. LPE cant be the only source.
To FAST install
