super detailed instructions and pics-wish I had some talent in the electrical field ( no pun intended) .
The fog lights Kind of makes it look like a C4 now--------------that is not a bad thing
From: Wylie TX --> Less is More, except under the hood !
Thanks for the compliment on my procedure.
I am soon going to write a full procedure on my Stainless break line install with brake fluid flush, and a LG GT2 Coil over install.
Originally Posted by phils C5 vette
I wouldnt install the stock lamps because the bulbs arent that bright. When guys replace the stock lamps for better ones, they go with Piaa 1100x. it comes with all the wiring
I installed stock Fog Light housings then install 6000K HID's in them.
They kill the PIaa lights by a long shot.
Originally Posted by Gear Jammer
Yes, Ive read your website (nice page, btw)
From the looks of things, you just mounted the foglights to the frame, no need for the factory plastic housings?
Thanks !
You mean the OEM foglights ?
I mounted the Factory GM fog lights just like the factory did (I think). I got my Factory OEM fog lights off of a parted out C5.
Why would anyone even add the stock fog light housings to a Z06? They're not needed for the fog light install. All that they do is block out the air flow to the engine. Actually, I just received my Z06 screens for my C5 coupe and I was planning to completely remove the plastic fog light housings. Is this a bad idea? Maybe there's something that I'm missing.
Originally Posted by Cybermind
I have a question.
I'm with you.... I'm also not sure why anyone would add that to a Z06. I did not when I put in my OEM C5 fog's to my Z06.
I don't think it performs a real function... I could be wrong though...
