Georgia emissions concerns
Old Jan 29, 2010 | 10:59 AM
Z1LE's Avatar
Z1LE
Navigator
Default Georgia emissions concerns
Hey guys, I just moved from St. Pete, FL to Roswell, GA. I found out that cars have to be emissions certified here. My car currently throws a code for the 02 heater (po141). Would this fail my car? If there are any GA residents out there, please chime in and let me know how stringent or lax the laws are here regarding mods. Right now the car is stock, but I want to mod. Also, it is a 2001 so I have the four cat exhaust. I was hoping to do two cats like the 2002 and up cars. Would they catch onto this? Thanks for any help guys.
Old Jan 29, 2010 | 11:05 AM
lucky131969's Avatar
lucky131969
Perhaps this will help:
http://www.cleanairforce.com/motoris...iontesting.php
Old Jan 29, 2010 | 12:39 PM
Chevy Guy's Avatar
Chevy Guy
Crazy thought here, but why not replace the sensor?
Old Jan 29, 2010 | 04:24 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Ive never had to do any of that with mine. Ive had GA plates on it for over 3 years and never had to do a test???
Old Jan 29, 2010 | 07:51 PM
GM Fan's Avatar
GM Fan
All they do is hook up a reader to your ECM and basically check for emissions related codes. They do a visual check for cats but they have zero knowledge on what years had what cat setup, they just need to think they see a proper cat setup. And they test that your gas cap holds pressure. Takes almost no time at all if you're not throwing codes. Just get that sensor replaced or the code programmed out and you're good.
Old Jan 30, 2010 | 02:22 PM
0331MARINE's Avatar
0331MARINE
Originally Posted by ~Joshua
You probably dont have it plated in one of the counties in and around metro Atlanta...
Everywhere else in the state has no checks.
Oh ok I didnt know it was just Atlanta area. Thanks
Old Jan 31, 2010 | 10:00 AM
Z1LE's Avatar
Z1LE
Navigator
Thanks for all of the replies. I was under the impression there was some sort of separate heater for the o2. Is the heater actually built into the sensor then?
Old Jan 31, 2010 | 11:36 AM
lucky131969
Yep
To Georgia emissions concerns
