Need help doing oil pressure test
Old Jan 29, 2010 | 06:09 PM
1SikVette's Avatar
01SikVette
Former Vendor
Default Need help doing oil pressure test
I've located the port on the front drivers side of the block. Where would I get the fittings needed to do the oil pressure test? So far I've picked up a mechanical gauge from Autozone but I doubt it has the right fitting to screw in the block.
Old Jan 29, 2010 | 08:44 PM
lucky131969's Avatar
lucky131969
Check out the oil pressure sticky(adapters are listed). If I'm not mistaken, the OPS thread and the plug in the block are the same.
Old Jan 29, 2010 | 09:24 PM
Its_Go_Time's Avatar
Its_Go_Time
This is what I use...it's an adapter fitting from AutoMeter(#2268) which converts the 16mm x 1.5 block threads to 1/8 NPT. Once you have a pipe thread, you should be able to connect your gauge, either directly or with pipe adapters. I use a quick disconnect on the end of my gauge to make it easier to hook up and keep clean.
To Need help doing oil pressure test
