seat question
Old Jan 30, 2010 | 09:27 PM
die hppy's Avatar
die hppy
Default seat question
sorry for the dumb question, but is possible to swap a power seat with the passanger manual seat. The driver seat is starting to ware and was not sure if you can un-bolt and swap just the seats minus the controls etc...
Old Jan 30, 2010 | 09:38 PM
byronhunter's Avatar
byronhunter
That Power Seat Switch will be hard to get to! Plus a few other problems.
Old Jan 30, 2010 | 10:04 PM
dougbfresh's Avatar
dougbfresh
Can you put your left shoe on your right foot?
Old Jan 31, 2010 | 02:46 PM
Jet-Jock's Avatar
Jet-Jock
The seat cushion should be identical. You may need to take both seats out, to swap the cushions. C4's you could do that in about 10 seconds.
Old Jan 31, 2010 | 03:07 PM
Its_Go_Time's Avatar
Its_Go_Time
The sliders are mirror images of each other. I think you could put the complete passenger side on the dirver's side, but the seat belt buckle will be by the door instead of towards the centre console... The seats themselves are identical, I think. They're held on by four kinda hard to reach nuts from below. You could probably switch just the seats themselves, and leave the sliders where they are. As was mentioned, you'll have to pull the switches from the drivers's side seat. The whole thing sounds like a pain in the *** to me...
Old Jan 31, 2010 | 07:24 PM
ragtopC5's Avatar
ragtopC5
I just replaced the seat covers in my car. The seats are 100% identical. The only difference is the bezel for the controls. You can bolt the seat belt buckle to either side of the seat. The only problem is you have to cut a hole in the cushion to attach the controls. You would have unused holes in the fabric on the right side and have to cut new holes in the left side.
Old Jan 31, 2010 | 08:32 PM
die hppy's Avatar
die hppy
Default seats
hey thanks for the the info. does not seem worth the hassel, I'll start looking for a used replacement.
To seat question
