A couple of weeks ago I ran very low on fuel before filling up. Since then I've noticed that my idle is much rougher than usual. It has a cam and has always had a good lope but now seems like it just won't hold a good idle. I've tried replacing the fuel filter, retune the computer, and gm idle relearn. I checked the vacuum hoses i see but am fairly new to ls1's. After about 1500rpm the car runs great which makes me think it is vacuum related. Does anybody have good vacuum hose pictures so I know where to look? Or maybe any tips in general on what's wrong.
What size is your cam? with cold startups in cold weather its not un common for a you to get cam surge. I have it in my car and my cam isnt very large at all. 222/222Dur Lift563/563 on a 114 LSA. It can take a a fe wminuted for the car to learn where the cam is at for it to settle down.
Check behind the intake manifold there are a few vacuum hoses back there..
