HELP! Cant get a spark plug back in!
Old Jan 31, 2010 | 11:33 PM
AZvetteman's Avatar
AZvetteman
Default HELP! Cant get a spark plug back in!
Been fighting it for hours. It is the drivers side plug closest to the firewall (#7?) and is a real PITA. Got it out somehow after fighting it but no luck getting it back in strangely. Even had the wife take a shot at it with smaller hands. Can get it in a couple half turns but then nothing. I cant tell if it is cross threading but the others went in easy in tight spaces too so I dont think so. Assume I just can't get the angle. I have a pretty good stash of tools and tried different extensions, a swivel/angle attachment (?), from top and bottom (nothing doing from here), and just frustrated. Heck did the belt, radiator, fans, condenser cleaning, fuel filter, PCV, etc. and this plug has given me the worse time. Any tricks, special tools that help, or something I should remove as it is crowded. Just cant get the right angle and then room for any leverage.
Old Jan 31, 2010 | 11:42 PM
SUNNYD 95's Avatar
SUNNYD 95
Take the coil pack off of the valve cover, you will have all kind of room to get the plug in.
Thats the way I do it and I have big hands.
Good luck
Old Feb 1, 2010 | 12:10 AM
AZvetteman's Avatar
AZvetteman
Good luck
Not so familiar with all this stuff ... is this the 5 or so 10mm(?) bolts to get it off and looks like an electrical connector also and then it pops off? ... just wanting to make sure. Thanks.
Old Feb 1, 2010 | 12:16 AM
c5blkvetteguy's Avatar
c5blkvetteguy
One trick is to put a small section of rubber hose thats fits over the end of the plug. This acts as extension and if the plug is not going in right, the rubber will slip on the plug so you cant put to much pressure on the threads to strip them out. A handy trick taught to me over 20yrs ago.
Old Feb 1, 2010 | 12:19 AM
AZvetteman's Avatar
AZvetteman
Thanks, maybe I will try to slip an old plug wire on as I replaced the wires too.
Old Feb 1, 2010 | 01:16 AM
LoneStarFRC's Avatar
LoneStarFRC
Yes. There are 5 10mm bolts and the one electrical connector. Removing the coil pack really helps me a lot.
I would caution that maybe, during your attempts, you have maybe very slightly started to cross-thread already, so getting the angle right and only using moderate torque may be even more important now. Slow and easy wins the race on this one.
Old Feb 1, 2010 | 08:05 AM
RSchleder's Avatar
RSchleder
I also assume that you have removed the small rubber hose from the brake booster, this, along with removing the coil pac will really open things up for you. Good luck, Ron
Old Feb 1, 2010 | 08:47 AM
rebelheart's Avatar
rebelheart
If you still are having problems after using all this good advice,you may need a thread chaser to clean up the threads.
Old Feb 1, 2010 | 09:21 AM
AZvetteman's Avatar
AZvetteman
Any further info on what hose this is to help identify it and how to remove? I will take a look ... was starting to think should remove some of the stuff was trying to work around but had not heard anyone needing to do do this in my initial searching. Thangs again everyone!
Old Feb 1, 2010 | 10:03 AM
LoneStarFRC
I think he's speaking of the vacuum hose attached to the brake booster. Personally, I would hardly call that one a "small" hose as it's approx. 1" in diameter. It's not too hard to disconnect. I usually just leave the check-valve attached to the hose itself and pull the check-valve out of the rubber grommet and then fold the hose back out of the way. As long as you don't damage the grommet, you're golden.
Old Feb 1, 2010 | 11:10 AM
dougbfresh's Avatar
dougbfresh
I always use a piece of vacuum hose to start the new plug. It allows me to start the plug in awkward places and it's almost impossible to crossthread (the hose will spin 1st).
Old Feb 1, 2010 | 07:34 PM
tiojames's Avatar
tiojames
I made one from an old plug. Taper the first 2 or 3 threads with a grinder, then cut 4 slots thru the threads with a hacksaw. Works like a charm.
Old Feb 1, 2010 | 09:06 PM
ALLEGRO's Avatar
ALLEGRO
Whichever method you choose, be careful, aluminum is not very forgiving
Old Feb 2, 2010 | 04:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you cant screw the plug in at least 3/4's of the way with your fingers, the threads are damaged. Find a thread cleaning tool (sears has them) and see if you can clean up the threads. If you force the plug in with a ratchet, you will destroy the threads. The next time you remove the plug, all you will have left is a hole with NO THREADS. Seen it a couple of times on aluminum heads.
BC
Old Feb 2, 2010 | 06:10 AM
Blown 346's Avatar
Blown 346
I agree, if it doesnt go in, go and get a tap and re tap that hole. You do have to get the right angel when tapping, or you will have more issues.
Old Feb 2, 2010 | 08:22 AM
craig04c5's Avatar
craig04c5
Also check the threads on the spark plug. Maybe take one of the easy ones to get to out and try and use that one. Just maybe you got a badly threaded plug. Like said above should go about 3/4 of the way in by hand don't try and turn it with a socket if you can't. Threads on the plug are harder than the threads in the engine.
Old Feb 2, 2010 | 10:31 AM
RogerZ06's Avatar
RogerZ06
Extensions and swivel are your friend. Try changing plugs on 94 C4.
To HELP! Cant get a spark plug back in!
Old Feb 2, 2010 | 11:33 AM
hotwheels57's Avatar
hotwheels57
Pay attention to what Bill Curlee said above.
You don't want to use a tap on the threads, it will remove metal.
You might need a tool that "chases" or cleans the threads of carbon/oil/dirt. It'll also help align the threads unless they're really damaged.
I used to have a '67 Mustang GT 390. There was about 3/4" of clearance for spark plugs. It was easiest to drill holes in the inner fender to allow access.
Old Feb 2, 2010 | 12:10 PM
wcsinx's Avatar
wcsinx
You don't need a special chasing tool. Just take an old plug with good threads, get your rotary tool with a cutoff wheel, and make about half a dozen deep slices perpendicularly through the threads. *Bam* there's your thread chaser. Take that thing in and out a few times, and if there's any crud on the threads, it'll end up in those grooves you just cut.
And I agree with the others here. You do NOT want to cross thread a sparkplug. I normally stick them into a sparkplug socket, and then thread them all the way down by hand (as in, I don't put a wrench on the socket yet). If I can't get them seated by hand, then I back off and try again. I probably don't even put a 1/8th turn on the wrench after I've got them spun down this way.
Don't be lazy. Pull off everything in your way. Yank the booster hose, coil packs, EGR pipeing, and maybe even the valve cover! Trust me, pulling the engine to fix a plug hole that you bunged up will take much MUCH longer.
Old Feb 2, 2010 | 09:58 PM
AZvetteman's Avatar
AZvetteman
Thanks everyone. Will remove some stuff and take another shot at it by hand and/or with some sort of rubber hose attached this weekend. It did seem the original plug came out a bit harder than the others even after loosened but that could have just been perception as it was 100% by socket at weird angles and many extensions etc. Just gonna hope for the best as I really had no "feel" since was working in such a tight spot but I did not try to force it once meeting resistance after a couple half turns so hopefully there is no real damage and just need to get a better angle on it or clean the threads a litte.
What size thread chaser/cleaner do I need to get (or perhaps I will just try the homeade version from an old plug)?
