keyless remote c5
Old Feb 1, 2010 | 09:35 PM
jbhesse's Avatar
jbhesse
Default keyless remote c5
Remote is intermitent; always opens the passenger door, but most time does not open the driver side door, always opens the hatch
Old Feb 1, 2010 | 10:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Probably a bad relay in the door control module.
Old Feb 4, 2010 | 06:56 PM
JMVett's Avatar
JMVett
1st Gear
You might have a bad FOB - keyless remote. You can buy the OEM remote from keylesssuperstore through ebay for $12.99 each. I bought two, it is the exact remote the dealership sells for $90! Programming is very simple, see your Vette manual, or paperwork from keylesssuperstore.
Old Feb 4, 2010 | 07:19 PM
byronhunter's Avatar
byronhunter
Might want to read this thread. Could be your problem, or maybe not.
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Feb 4, 2010 | 08:19 PM
KrenzyRyan's Avatar
KrenzyRyan
Does your interior door lock/unlock button work every time you use it?
Old Feb 5, 2010 | 08:52 AM
65GGvert's Avatar
65GGvert
You're assuming he has a 2001 or up car. Since he did not say in the question and also has not filled out a profile, there is no way to know. He won't buy the older fobs from anyone for less than $60, even used. In addition, the fob will not be the cause of the driver door only not unlocking. If the other door always opens with the fob, there is not a problem with the fob.
To jbhess, when you ask a question, list the year and style Vette you have if you want accurate answers. A new fob will not fix your issue. Follow the advice offered about the door wiring and relays.
To keyless remote c5
