Broken Coilover??
Old Feb 1, 2010 | 09:43 PM
MarkT 2002's Avatar
MarkT 2002
Default Broken Coilover??
Anybody ever broken a coilover? I think I just did
Old Feb 1, 2010 | 10:37 PM
niteriderc5's Avatar
niteriderc5
...what brand? Also what makes you think you "broken a coilover"? need more info man!
Old Feb 1, 2010 | 10:46 PM
convertz's Avatar
convertz
Broke a spring? Blew out a shock? Snapped some hard parts?
Old Feb 1, 2010 | 11:23 PM
Brandon619's Avatar
Brandon619
Are they a Famous brand? I've seen more than five coilovers broken from this company. The shock steam on the coilover just snapped off.
Old Feb 1, 2010 | 11:31 PM
MarkT 2002's Avatar
MarkT 2002
Sorry for being a little cryptic.
The manufacturer, Pfadt, is reacting in a stand-up way and I am in no way throwing stones. I've had my coilovers for 23 months and other than the loose nut issue in the first week they have been great.
It appears that I snapped a hard part, the top of the shock shaft where it meets the bottom of the flange on-top of the spring. It's my right rear wheel and sounds very much like the loosening nut issue; problem is when I got in there I could see the separated shaft/flange and could see the only thing keeping the shock from falling against the spring is the ~1/8" adjusting rod that runs up through the shaft/upper bolt.
Curios if anyone else had this problem and what may have caused it. I don't recall hitting any potholes, curbs or anything that gave me any kind of jolt.
Old Feb 1, 2010 | 11:37 PM
chriswtx's Avatar
chriswtx
At least its a heads up for guys to look out for it...
Old Feb 1, 2010 | 11:40 PM
lucky131969's Avatar
lucky131969
My friend had exactly the same failure last year, same brand, and just so happens.....it was the right rear
Old Feb 2, 2010 | 09:45 AM
jkz06's Avatar
jkz06
What nut has the issue with coming loose?
Old Feb 2, 2010 | 12:03 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
This is something I will need to monitor, was the broken shocks the first version or the ones with the new tops
Old Feb 3, 2010 | 12:56 AM
MarkT 2002's Avatar
MarkT 2002
In their earlier version the top mounting nut had a tendency to loosen up, they have come out with a later version that fixed the problem - in my case since I have the earlier version I ended up having it double nutted and that solved the problem.
I believe mine is the first version, I'll know for sure when I see the replacement body. In any case apparently there is a later version that includes a small brass sleeve/ring that goes over the shock shaft near the upper flange to add strength to help prevent the shock shaft/upper flange from shearing. Mine definitely did not have the brass sleeve/ring.
To Broken Coilover??
