Disaster in Garage
Old Feb 8, 2010 | 10:47 PM
  #61
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Default ...based on that pic...
consensus on that harmonic balancer showing a little too much rubber?
Old Feb 8, 2010 | 11:30 PM
  #62
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I went over everything and it all checked out. The only damage was from the jack stand pretty much going through the driver side fan!
Old Feb 8, 2010 | 11:49 PM
  #63
lionelhutz's Avatar
lionelhutz
It's fine, that's the opposite (bottom) and inside part of the balancer....
Peter
Old Feb 9, 2010 | 12:09 AM
  #64
kg54trains's Avatar
kg54trains
Originally Posted by Sargechris
No worries--I appreciate any and all feedback!!
The wheels, thank goodness, were still on... So the damage was from the jackstands hitting the fan shround and surrounding parts... But, so far, all I can tell is the fan assembly needs replacement..
A thread on the Forum shows the use of a piece of equipment called a cross beam adapter that is a stable steel bar that has adapters that slide out to adjust to the support brace and jacks. Looks like the best way to jack up a car with a stable result.
Old Feb 9, 2010 | 05:10 PM
  #65
Sargechris's Avatar
Sargechris
Saw it. Thanks!!
Old Feb 9, 2010 | 09:57 PM
  #66
Jet-Jock's Avatar
Jet-Jock
Wow, in one sense you were lucky. Glad it turned out for the best and kudo's to the forum member for their help.
Just a couple observation points I didn't see specifically mention. When reading the section in the FSM, the point they make regardless of the method of lifting, the contact point must span at least two ribs.
It is most apparent and easy to see this by examining the front cross member. From underneath, you'll notice at the lift point there is a circle of rib material with ribs radiating outward into other channels of rib material. You want your pad to span two of those ribs. Never let the jack to physically touch the lift point, use a pad of some sort, be it wood or metal.
Some people like to use a 2x6x18 piece of wood which for the rear section spans all ribs and extends about an inch on each end. As you jack the rear end you will place jack stands at each of the preferred lift points. Then let the hydraulic jack down just a little to allow the weight of the vehicle rest of the jack stands.
You might consider using car ramps with the pre-ramps to put the front up, then secure the wheels with chocks. Then raise the rear as described above and place the jack stands in place. I would think that would be a much preferred and safer method for using a combination of devices.
Sure everyone would luv a real lift.
Perhaps what happened was as the rear was being lifting, it also moves forward because when the front was lifted it put the rear at an angle that had to move slightly forward as it lifted, thus causing movement and jack collapse.
To do your own oil changes you need to get the vehicle up on all fours, so that the oil pan is level.
Old Feb 9, 2010 | 10:44 PM
  #67
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Very nice of you to help him out.
Old Feb 10, 2010 | 11:11 AM
  #68
Sargechris's Avatar
Sargechris
I believe that is exactly what happened... Thanks!
Old Feb 11, 2010 | 01:09 AM
  #69
98am's Avatar
98am
Bad experience but a good lesson learned and I'm glad you didn't get hurt. Best of all you got to meet a great young man that this country can be proud of, Thanks Chris
Old Feb 11, 2010 | 01:45 AM
  #70
0331MARINE's Avatar
0331MARINE
Semper Fi
Old Feb 11, 2010 | 04:51 PM
  #71
Sargechris's Avatar
Sargechris
Default Fan Motors, 1 Fan
I just could not toss these in the trash before asking: anyone interested in my 2 fan motors and the remaining good fan blade? My Vette has 24k miles and the fan motors work just fine...
No charge--I'll even pay for the shipping! (maybe I should have posted on the "pay it forward" thread, but it's directly related to my "disaster")
GM Parts Direct says the following:
Fan motor, corvette 97-04 $115.82 $60.23
Fan blade, corvette 97-04 $73.48 $38.22
PM me if you think you might put these to use...
Old Feb 12, 2010 | 10:15 AM
  #72
tramminc's Avatar
tramminc
There was a post 2 -3 years ago, which showed a yellow C6 that fell off a large 2 post lift at a dealer. the *** of the car was up and the nose was down.
Old Feb 12, 2010 | 11:16 AM
  #73
Tech's Avatar
Tech
If you ever have to lift the front and the rear, I recommend having 2 jacks and making sure that each jack is able to freely roll (no little pebbles/rocks in the way of the wheels). I typically raise and set the front of the car on a set of jackstands on their lowest setting. Then jack the rear. Then jack the front again.
Kudos to the Marine that came to the rescue.
Old Feb 12, 2010 | 08:39 PM
  #74
Sargechris's Avatar
Sargechris
Did about 60 miles today... A-OK!! No noise, squeaks, rattles.. And temp stayed around 180-194*....
Very, Very Happy!!
Thanks again to all for the info & to my new "best friend" Chris!!
Old Feb 12, 2010 | 10:01 PM
  #75
Daddyrama31's Avatar
Daddyrama31
Your a good person. There should be more like you who just want to help out others. Your son will learn from your generosity.
Take care,
Dave
Thanks alot guys. Like I said I was just glad I could help out.
Old Feb 13, 2010 | 08:18 AM
  #76
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Wow, what a story! Thanks for sharing it!
It seems we are inundated with all the bad stuff on the news and just don't hear many stories like this one. 0331MARINE, Chris is obviously an outstanding person and will be rewarded for his willingness to help others. If I was in the military I'd be honored to serve at his side and / or under his leadership!
Old Feb 13, 2010 | 02:35 PM
  #77
happiedazs's Avatar
happiedazs
Love those Marines!!! --- and thanks for serving America and also helping out your Corvette brothers
To Disaster in Garage
Old Feb 14, 2010 | 05:25 PM
  #78
Dave1998's Avatar
Dave1998
Great story
Old Feb 14, 2010 | 08:39 PM
  #79
0331MARINE's Avatar
0331MARINE
Dang I didnt know this thread was still going on!!!!
Old Feb 14, 2010 | 09:00 PM
  #80
matt75's Avatar
matt75
Thanks for your service and great thread!
