Car won't start
Old Feb 10, 2010 | 02:55 PM
jodyeastman's Avatar
jodyeastman
Default Car won't start
So the car has only been run a few times over the winter but I went out to start it yesterday and it would not start.
The cabin lights come on and radio but it's a little weak. As I turn the ignition I hear fast ticking. I'm thinking my battery is weak but it may be the starter or fuel pump (maybe?)
Any ideas?
2001 Z06
Old Feb 10, 2010 | 03:10 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Common Issue is that these cars draw power when not in use to run the BCM and some other controls.
Jump start using some battery cables and buy your self a battery tender from CCA (Aka Chip) here on the forum.
Here's a link
http://www.customcorvetteaccessories...rycharger.html
Any ideas?
2001 Z06
Old Feb 10, 2010 | 03:22 PM
lucky131969's Avatar
lucky131969
Any ideas?
2001 Z06
If the engine will not even crank, how could it be the fuel pump? Check the condition of your battery, or try to jump start the car.....
Old Feb 10, 2010 | 06:44 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
As suggested already, you need a full battery for things to work. The battery needs a solid 12.5vdc across the terminals without the key on, for the electronics to work. It will turn over with less voltage, but the computers will not run.
Old Feb 11, 2010 | 01:27 PM
jodyeastman
Thanks for the input guys. It's just odd because the battery is only a year oild and I drove it only about 1.5 months ago. I'll put a meter on it tonight and check that out.
Old Feb 11, 2010 | 01:38 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your car will only go about a few weeks probably for the battery will be drained. If you drive it that infrequently get a battery tender.
Old Feb 11, 2010 | 07:36 PM
dgrant3830's Avatar
dgrant3830
I agree. 1.5 months without driving it will cause you problems. As stated, put a trickle charger on it or something to keep it fully charged.
To Car won't start
