Replacing Stock Bolts
Old Feb 10, 2010 | 03:41 PM
Javi1782's Avatar
Javi1782
Default Replacing Stock Bolts
Guys,
I ordered a set of lowering bolts for my 02 coupe, I did a search to see if there is a write up on how to change them but only found threads on how to lower the car on stock bolts and nothing on actually replacing bolts " maybe I suck at searching". If anyone here has any info can you please let me know.
Thank you in advance,
Javi
Old Feb 16, 2010 | 05:39 PM
Javi1782's Avatar
Javi1782
Old Feb 16, 2010 | 05:54 PM
Dennis Wilson's Avatar
Dennis Wilson
Originally Posted by Javi1782
Guys,
Javi
Front? Rear? Both?
Old Feb 17, 2010 | 08:09 AM
Javi1782's Avatar
Javi1782
Both
Old Feb 17, 2010 | 09:51 AM
Dennis Wilson
The rears are easy, Jack the car up to take the weight off wheels And you can switch out the bolts in just a few minutes. With the wheels off they are right in front of you. The fronts you have to drop the lower A arm to get clearance to turn the bolts down out of the spring. I cut the bushings on mine without removing anything. You can try typing in "removing lowering bolts" I have seen pics on here showing the process of A arm removal. I hope this helps you some. Good luck. Dennis
Old Feb 17, 2010 | 02:18 PM
Javi1782's Avatar
Javi1782
Thank you Dennis for all your help!
Old Feb 17, 2010 | 08:59 PM
don hall's Avatar
don hall
Default bolts
The info in this link may help:
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old Feb 17, 2010 | 09:46 PM
toddz1217's Avatar
toddz1217
Default Were did you get them?
Just curious who you purchased them from.
Old Feb 18, 2010 | 02:52 PM
Javi1782's Avatar
Javi1782
I ordered them from Zip
To Replacing Stock Bolts
