Has anyone dropped a crate LS7 into their C5??
Old Feb 11, 2010 | 10:22 AM
FLYNAVY30's Avatar
FLYNAVY30
Default Has anyone dropped a crate LS7 into their C5??
Just curious...I was looking into it 2 years ago or so...and now the cars finally paid off . I know theres some issues with knock sensor location and reloctor wheel compatability, getting an oil pan to run wet sump, etc...just wondering if anyone on here had done the swap.
Old Feb 11, 2010 | 12:20 PM
vettenuts's Avatar
vettenuts
I have looked into this as well and based on all I have found if doing this today I would contact Va Speed for a sleeved LS2. I think the installation problems are greatly reduced and so is the cost. The LS7 is a nice motor, but there are a number of things required that wouldn't be with an LS2 block unless you need features such as dry sump.
Old Feb 11, 2010 | 12:25 PM
FLYNAVY30's Avatar
FLYNAVY30
yea I definately dont need dry sump, etc. When I was looking into it a few years ago, I had found a company that would take a stock LS7 crate motor, put the pan on it for wet sump, convert the reluctor wheel, and include the harness adapters to make it a drop in ordeal...it wasnt cheap, I think it was around 15K, but in thinking about it, the idea of 1.) a legit 427 in my C5 was kinda cool, 2.) reliability of a bone stock crate motor, 3.) GM warranty still good on the motor. Ill have to see if I can dig up the company and the old emails...
Old Feb 11, 2010 | 01:37 PM
WKMCD's Avatar
WKMCD
A Darton sleeved LS2 will be stronger than an LS7.
Old Feb 11, 2010 | 04:15 PM
Han Solo's Avatar
Han Solo
Car Craft or Hot Rod magazine did an article on converting the LS7 to wet sump recently. I'll try to look when I get home and see which mag it was.
Edit: Found it online. http://www.hotrod.com/techarticles/e...ion/index.html
Old Feb 11, 2010 | 06:25 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
How much of a price difference will your bullet proof LS2 be than a stock LS7
Old Feb 11, 2010 | 07:03 PM
zeevette's Avatar
zeevette
Lots of ways to get 427 CI, or more, that're better/cheaper than a LS7. Just a couple of weeks ago, a vendor was advertising various combinations of stroker motors for great prices, based on LS3 blocks, I believe. I'd go LS3, or 2 before crate LS7. Of course, Jay Leno went with a LS7 swap in his C5Z, but he's got a couple of extra bucks, if the rumors are true.
Old Feb 11, 2010 | 08:14 PM
DIXZ's Avatar
DIXZ
I have installed 418" stroker LS3 in my C5 Z06 and my friend has a 427" LS7 in his. Both were fun projects!
Old Feb 11, 2010 | 10:35 PM
FLYNAVY30's Avatar
FLYNAVY30
yea, I realize that you can probably make more power for the same money off a stroked LS2/3, but theres still something appealing to me about just buying the LS7 crate motor from scoggin dickey and dropping it in, especially if I can get the necessary parts to essentially make it a plug and play application
Old Feb 11, 2010 | 11:52 PM
LoneStarFRC's Avatar
LoneStarFRC
That's exactly what I did too, though it wasn't done in Virginia.
Old Feb 12, 2010 | 05:16 AM
tnsyty's Avatar
tnsyty
Since you are on the topic, what is the easiest swap into a C5? I like the LS3 and LS7 but have heard they are both more difficult. I wanted to do H/C on my 98, but a new engine might be the ticket. If I were going LS7, i would just get the C6Z
Old Feb 12, 2010 | 08:34 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I am having an LSX block built up. Its cast iron!
Old Jan 19, 2011 | 11:43 PM
SDLS1Rider's Avatar
SDLS1Rider
I'm thinking about doing this. How does this affect smog. PM me the answer if you like?
Old Jan 20, 2011 | 04:01 AM
MPM IV's Avatar
MPM IV
I wouldn't do the crate motor either. Why not get more power and upgrade some parts before it's installed? Also, I wouldn't limit myself to 427 ci. ERL sells a dry sleve 454 shortblock for $5000.
I went with the LS7 block three years ago. I would probably do things a little different now, but I wouldn't go with the LS3.
Old Jan 20, 2011 | 07:03 AM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I bought a LS7 short block,Wet sump from SDPC a few years back and put it in my 97 with no problems.Make sure you get the 24x reluctor.It came with the knock sensor's and everything else to put it in.So far I put about 20k miles on it.And alot were 1/4 mile ...........Paul
Old Jan 20, 2011 | 08:15 AM
7LitreC5's Avatar
7LitreC5
That is the route that I went as well. Doing it this way is a little bit less spendy vs. the LS7 crate engine.
clif's Avatar
clif
I am building a killer 454 for my vert!
To Has anyone dropped a crate LS7 into their C5??
Old Jan 20, 2011 | 01:38 PM
BitViper's Avatar
BitViper
Originally Posted by SDLS1Rider
I'm thinking about doing this. How does this affect smog.....
Yeah.. sometimes living in Cali is a bitch
Old Jan 20, 2011 | 02:34 PM
SDLS1Rider's Avatar
SDLS1Rider
I've heard it can be done. But I just wondering if anyone has actually done it and passed smog? Sure, somebody knows a guy who knew someone. But getting a crate engine LS7 then putting it in only to find out it won't qualify would be a major B****!!
Old Jan 20, 2011 | 02:44 PM
dankhts's Avatar
dankhts
read a post last fall, CF member had an LS7 built up and installed in his C5 - might have been done by Vengence or one of the other vendours down that way - can't exactly recall which one though, as I recall it worked out pretty good! A local forum member up here is presently doing it to his '99 coupe.... figuring it out by himself, but then again, he owns a good shop and has some good techs available....
