Air pump removal before tune?
Old Feb 13, 2010 | 08:30 AM
vettenuts's Avatar
vettenuts
If you are running headers, I prefer cutting of the tube and welding the pipe shut. A lot of guys have broke that weld using block off plates and most header manufacturers will not recommend them for that reason. I just had this done on my LG Pros that are being installed when the snow goes away.
Old Feb 13, 2010 | 11:04 AM
c5blkvetteguy's Avatar
c5blkvetteguy
When my headers get here I will have that done right away.
Old Feb 13, 2010 | 11:08 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The best way is to simply have the headers built without the flanges.
Old Feb 13, 2010 | 11:18 AM
lucky131969's Avatar
lucky131969
Sorry, I missed you are doing headers. Y2Kvert4me is right on time.
Old Feb 13, 2010 | 12:06 PM
corvettebob1's Avatar
corvettebob1
OK, you got my curiosity up how do you break the weld using block off plates?
Old Feb 13, 2010 | 01:02 PM
vettenuts's Avatar
vettenuts
Appears to be a vibration problem cracking the welds.
Old Feb 13, 2010 | 01:25 PM
Last C5's Avatar
Last C5
As strange as it sounds, I've seen this happen several times and on several different manufacturer's headers. Personally I don't believe it could be vibration, my theory is that tiny little track gremlins crawl into the engine bay late at night and use tiny little air chisels to weaken the weld.
Old Feb 13, 2010 | 02:14 PM
happiedazs's Avatar
happiedazs
Its not all about power. I dont run fuel rail covers (dont like the look) and want to "clean-up" the engine bay and make it the way I think it should look.
If you are seeking more "engine bay" clean-up projects while you are snowed in --- here is something you may consider.
http://forums.corvetteforum.com/c5-t...many-pics.html
I think it's totally crazy --- but I've done a lot of crazy thing myself so Its all just personal taste.
Have Fun and pray for an early spring
Old Feb 13, 2010 | 02:35 PM
c5blkvetteguy
I dont like the idea of relocating the coil packs. I have seen pics of a valve cover with the coils hidden underneath them....that I like! I'm not sure who makes them or the cost.
Old Feb 13, 2010 | 03:07 PM
vettenuts's Avatar
vettenuts
That was ABEAR and I don't think they are in business any longer.
Old Feb 14, 2010 | 04:49 PM
c5blkvetteguy
Is there another company that makes them?
Old Feb 15, 2010 | 01:38 PM
Z06 Nate's Avatar
Z06 Nate
What would it take to weld up a set?? Could you just make a "cap" to fit over the valve covers?? Glad I found this thread, a few other guys and I have been going back and forth about a header install and how to remove the AIR system. http://forums.corvetteforum.com/c5-t...hing-else.html So thanks
Nate
Old Feb 15, 2010 | 10:21 PM
  #33
Bill Dearborn's Avatar
Bill Dearborn
Would it be a good idea to cut the tube off the air line connector (part that will be removed) and just weld that hole closed? (instead of buying block-off plates). That way I can use the same bolts that held the line on and it would be free.
25 years from now some guy will be cursing you for making such a choice. These are the kinds of parts that become very valuable when people are restoring cars. Just look at the prices AIR equipment from the late 60s brings nowadays. Don't toss it or cut it up.
Bill
Old Feb 15, 2010 | 10:22 PM
  #34
c5blkvetteguy
If I cant find anyone that sells that type of valve cover...I guess I will have to design and build my own.
Old Feb 15, 2010 | 10:24 PM
  #35
c5blkvetteguy
Bill
I never plan on selling my car. You can never get out what you put in. Down the road I might get another one...and track this one, who knows!
Old Feb 19, 2010 | 01:12 PM
  #36
Sinister-one's Avatar
Sinister-one
And what happens if a coil ever fails ??? Just askin.......
Old Feb 19, 2010 | 07:18 PM
  #37
c5blkvetteguy
Ya, I would never relocate the coils....just for that reason.
To Air pump removal before tune?
Old Feb 19, 2010 | 07:30 PM
  #38
Nick1's Avatar
Nick1
I would like to get rid of the mess due to the code problems coming up with the crappy check valves. There is an inspection problem here in New Jersey though. How can this be programmed out so as not to be a future problem? Can this be done as a DIY?? Thanks!
Old Feb 20, 2010 | 04:36 PM
  #39
Z06 Nate's Avatar
Z06 Nate
Originally Posted by PewtVette
There is no entry point into the intake manifold. It is only secured to the back of the intake manifold. To the drivers side head specifically. Here's mine (not going back on):
If you dont mind me asking....HOW THE HELL DID YOU GET THAT BACK BOLT OFF!!!! Am I going to have to pull off the intake manifold?
Thanks a ton,
Nate
Old Feb 20, 2010 | 10:37 PM
  #40
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Thanks a ton,
Nate
You will need to move the intake forward(or off). Then get at the bolt with a wrench.
