Tornado Fuel Saver
Old Mar 7, 2002 | 09:34 PM
steve1173's Avatar
steve1173
Default Tornado Fuel Saver
Anyone tried one of those Tornado fuel savers, my friend told me he installed one in his car (not a Vette) & it increased his mileage & HP. I am skeptical about it so I don't know. Anyone else hear about it or is it snake oil.
Old Mar 7, 2002 | 09:35 PM
SAXN8R's Avatar
SAXN8R
Default Re: Tornado Fuel Saver (steve1173)
It is a crock of shiznit!
Old Mar 7, 2002 | 10:03 PM
Dale RED 98's Avatar
Dale RED 98
Don't really think it's something for a CORVETTE!!! :nonod:
Old Mar 7, 2002 | 10:11 PM
GraveDigger's Avatar
GraveDigger
Local news caster (in your corner guy, really a d$ck) did a test on them and found them to be inefective. :yesnod:
Old Mar 7, 2002 | 10:12 PM
C5Cemo's Avatar
C5Cemo
Default Re: Tornado Fuel Saver (Dale RED 98)
Nothing but an intake restriction...prolly why they claim fuel mileage increases because there's less airflow to match :lol:
What works best for induction is laminar flow...not rolling turbulence.
Old Mar 7, 2002 | 10:15 PM
luvinc5's Avatar
luvinc5
Default Re: Tornado Fuel Saver (C5Cemo)
Hmm, I though this topic was brought up a couple of months ago?
http://forums.corvetteforum.com/zerothread?id=201270
Old Mar 7, 2002 | 10:31 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Tornado Fuel Saver (luvinc5)
NOT AGAIN!!! :cry
Old Mar 7, 2002 | 11:00 PM
Superj's Avatar
Superj
Yeah this thing has made the rounds and is a bunch of poo..Read here:
http://forums.corvetteforum.com/zerothread?id=235131
http://forums.corvetteforum.com/zerothread?id=222580
http://forums.corvetteforum.com/zerothread?id=127570
Old Mar 7, 2002 | 11:11 PM
GWPII's Avatar
GWPII
Default Re: Tornado Fuel Saver (Superj)
Get the real deal: HICLONE!
What is Hiclone?
"Hiclone is a simple non-moving and maintenance-free device make of stainless steel, which fits inside the air filter housing of a carburetor or in the air induction hose on EFI, turbo, LPG or diesel engines. Which creates a swirling cyclone or tornado like effect to the airflow into the intake manifold and combustion chamber of any engine".
Hiclone has No moving parts and will therefore out last the life expectancy of any engine.
Hiclone requires NO engine modifications and NO chemicals.
It is for these reasons that we offer a lifetime warranty and an unconditional 30 days Money-back guarantee.
Hiclone for air intake inside diameter up to 90 mm (most EFI/Diesel/Turbo engines)
$160.00 AU = $83.93 US
http://www.fuelsaver.com.au/hiclone.htm
The Hiclone must be better than the tornado fuel saver, 'cause you can use up to TWO of 'em! Can you do that with the tornado? :crazy: :crazy:
Old Mar 7, 2002 | 11:32 PM
maninblack's Avatar
maninblack
Default Re: Tornado Fuel Saver (GWPII)
hmmmmm, than why didnt any car manf. thought of it,when they are using
billions of dollars to develop the engine?,if this product are so good,I assume
every singal car would already had on 30 yrs ago....doesnt make sense :smash:
Old Mar 8, 2002 | 12:09 AM
C54TIM's Avatar
C54TIM
:lol: What he said!
[Modified by C54TIM, 8:10 PM 3/7/2002]
Old Mar 10, 2002 | 01:54 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
:bs
I can't believe that anybody would fall for that garbage. The entire concept of inducing more air by causing a funnel effect is completely flawed. Adding a funnel effect will only increase turbulance and decrease the overall airflow. But, if you put on TV it must work!? Right? WRONG!! :rolleyes: :nonod: :nonod:
Old Mar 10, 2002 | 04:50 AM
jorex's Avatar
jorex
Default Re: Tornado Fuel Saver (JTE)
If you didn't get the promised results from the device, you obviously did not properly apply the supplied package of Zaino to your MAF screen.
Old Mar 10, 2002 | 12:55 PM
BadBoy's Avatar
BadBoy
I hear its a bunch of :bs
Old Mar 10, 2002 | 01:47 PM
ghostmech's Avatar
ghostmech
GWPII, are you a distributor for this Hiclone crap? My advice is to stay away from Tornado, Hiclone, SlightBreeze or whatever they call this junk. And Please, don't come here and try to sell this garbage on this board :mad
Old Mar 10, 2002 | 01:53 PM
Fivo Killer's Avatar
Fivo Killer
Default Re: Tornado Fuel Saver (ghostmech)
If you want to increase gas mileage, follow my easy plan!!
Step 1) When accelerating, do it at a constant increasing speed
Step 2) If acosted by an import or Mustang, do not attempt to pursue
Step 3) If wanting to go over the speed limit, make sure one uses the cruise control
Step 4) Make sure not to go above 100mph for over 5 second intervals.
I mean come on... who in the hell would put something like that in their car. I hope there is someone on here so we can beat them with a broom handle. Who in their right mind would think that by putting something that restricts air flow, it would increase their MPG. Like someone said, maybe its just because less air = less oppurtunity to burn more fuel.
Old Mar 10, 2002 | 05:51 PM
GWPII's Avatar
GWPII
haaaaaaaaaaaahaaaaaaaaaa! ghostmech, please look at my post very carefully... See the crazy emoticons? That should be a hint what I think of gadgets like these :p:
Old Mar 10, 2002 | 08:13 PM
ghostmech's Avatar
ghostmech
ok..GWPII .......I'll pull the fish hook out :cheers:
Old Mar 10, 2002 | 08:58 PM
RyanC7's Avatar
RyanC7
:bs :bs :bs :bs :bs :bs :bs :bs
To Tornado Fuel Saver
