E-brake replacement
Old Feb 15, 2010 | 04:54 AM
mfarmdawg's Avatar
mfarmdawg
Default E-brake replacement
Anyone ever had to replace theirs? How much of a PITA is it to do without taking the lug-hub off? What size socket it needed to remove the lug-hub nut just in case?
I was driving my car recently and heard this nasty squeal and dragging noise. I put the car away in the garage until I could get back to it. Yesterday, I made some time and took the driver side wheel off and spun the axle by the lug nuts and found the noise, so I proceeded to take the rotor off and as the rotor was coming off, little chunks of material were falling out. Long story short, the e-brake linings had come off the shoe assembly and had wedged into spaces between the rotor and the shoe causing the nasty noises. The shoe and the rotor were undamaged, I have new shoes to put on, but needed some guidance. The passenger side seems to be fine as in no dragging noise as I spin the hub, and the rotor wouldn't come off. I have had some problems for awhile now with the e-brake hanging up and locking the driver side wheel up as I backed out of the garage or off the driveway, then I heard a clunk and nothing for a couple of days 'til it started with the dragging/squealing noise.
Old Feb 15, 2010 | 07:49 AM
dougbfresh's Avatar
dougbfresh
I think you could do it, last time I was in there to adjust mine it looked like you could replace the lining with some (very) long nose pliers.
Old Feb 15, 2010 | 11:44 AM
JPEAK's Avatar
JPEAK
Try the zip tie process. it worked for me.
http://forums.corvetteforum.com/c5-t...y-49-95-a.html
Old Feb 15, 2010 | 12:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The shoe replacement is easy except for ONE step. Theres a "W" shaped spring that secures the shoes to the backing plate. Its tough to get that spring over the shoe frames.
I used a long thin screwdriver with a grove filed in it to pop the spring over the shoe plate.
Theres a ZIP tie method that works very well. You install the zip-tie so that the teeth do NOT catch and you can remove it easily. You pull the zip-tie and pop the spring on the shoe.
Then just adjust the shoes so that there is a very SLIGHT drag on the drum. If you get the shoes too tight,,,it will get stuck on the shoes and you will end up pulling the shoes back out with the drum.
BC
To E-brake replacement
