lost 4th gear !!!!!!!!!!!!!!!!!!!!!!!!! drive it????????
Old Feb 15, 2010 | 06:34 PM
rustyguns's Avatar
rustyguns
Default lost 4th gear !!!!!!!!!!!!!!!!!!!!!!!!! drive it????????
Hey guys
slave cylinder was getting soft and i stripped 4th gear syncro and then it got stuck in 4th. luckily it popped backout and i finished the day with first second and third. track did not need 4th
think i can change the oil and get one more day out of it?
its prob the keys/dogs are broke for the 4th gear fork
Old Feb 15, 2010 | 07:28 PM
rustyguns's Avatar
rustyguns
Originally Posted by rustyguns
Hey guys
ttt no one?
Old Feb 15, 2010 | 07:35 PM
lucky131969's Avatar
lucky131969
What's the worst that can happen if you drive it?
Old Feb 15, 2010 | 07:48 PM
rustyguns's Avatar
rustyguns
Old Feb 15, 2010 | 08:18 PM
ragtopws6's Avatar
ragtopws6
Drain the fluid out of the trans and see what you find. Most of the metal particles will be caught by the 2 magnets but if you see silver metalic particles in the fluid, you will most likely need to open up the trans. Here is what happens when the keys/retaining spring goes out.
Old Feb 15, 2010 | 09:38 PM
rustyguns's Avatar
rustyguns
you cant get to magnets huh?
did your tranny work at all with that build up in it?
Old Feb 16, 2010 | 01:45 AM
ragtopws6's Avatar
ragtopws6
To get to the magnets you have to remove the tail shaft cover.
This trans didn't want to go into 5th (all 3 keys and springs was broken and stuck to the magnet). The trans needed $1,000 to repair but if this was caught earlier, he could have save some $$$.
Old Feb 16, 2010 | 03:05 AM
rustyguns's Avatar
rustyguns
I CAN DO IT MYSELF A LOT CHEAPER
To lost 4th gear !!!!!!!!!!!!!!!!!!!!!!!!! drive it????????
