squeaky sound when heater is turned on
Old Feb 15, 2010 | 08:59 PM
harleygal's Avatar
harleygal
1st Gear
Default squeaky sound when heater is turned on
Does any one know what causes a squeaky sound when the heater fan is turned on? I have a 2001 auto model, some have said it may be myserpentine belt or tensioner and it does ease if I use belt dressing but only for a short while before it starts again. would appreciate any suggestions on how to fix this.
Old Feb 15, 2010 | 09:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its most likely the HVAC Fan Motor. You can remove the motor and lubricate it which usually takes care of the issue. Its in the passengers foot well:
It looks like this,,, minus the mouse nest!
Remove it, lube it and see if that fixes your issue.
BC
Old Feb 15, 2010 | 09:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Probably your blower motor bearing starting to go. It's located in the passenger footwell under the close-out panel. Pop (pry) the (2) plastic plugs down to remove the close-out panel for acces to the blower motor.
Recommend buying new from Gene @ Gmpartshouse.com.
To squeaky sound when heater is turned on
