How does the wiper motor remove from the arm???
how does the wiper motor remove from the arm, I do NOT want to remove the ball/socket arm from the motor
I rem'd the Torx screw, but guessing this needs to be pressed off?
fwiw, if you remove the x3 10mm bolts that hold the transmission in, you can remove the x3 Torx screws that hold the motor to the trans and remove the entire assembly
thanks
