speedometer wont register
Old Feb 21, 2010 | 01:31 PM
Bammz's Avatar
Bammz
6th Gear
Default speedometer wont register
So I installed a new amp into the C5 and now the speedometer is pegged at 200. I also powder coated the rims so they were removed for a while. WTF?! any help would be appreciated.
Old Feb 21, 2010 | 02:08 PM
lucky131969's Avatar
lucky131969
Exactly what was disturbed in the amp installation?
Old Feb 21, 2010 | 02:54 PM
Bammz's Avatar
Bammz
6th Gear
I blew a fuse but it was just the amp fuse and replaced it. I checked all other fuses and they are all good. The heads up display works just fine with accurate speed but the dial is not working.
Old Feb 21, 2010 | 03:28 PM
lucky131969
What happens if you disconnect the battery?
Old Feb 22, 2010 | 09:31 AM
Bammz's Avatar
Bammz
6th Gear
Nothing, as I think about it more I may have drilled through the speed censor when I installed the amp. =(
Does anybody know where pits located on a C5? (speed censor)
Old Feb 22, 2010 | 10:34 AM
lucky131969
Yikes......
Old Feb 22, 2010 | 11:42 AM
byronhunter's Avatar
byronhunter
You did not drill through the Speed Sensor!!!!!!!!
Old Feb 22, 2010 | 11:49 AM
Bammz's Avatar
Bammz
6th Gear
Hey thank you lucky131969! that would explain why the speedo does not work. it is located rite on the top there...yup sent a screw in that direction. Good thing I am not an air craft mechanic.
Old Mar 1, 2010 | 04:11 PM
Bammz's Avatar
Bammz
6th Gear
Put the Vette on jacks this weekend and traced all screws and their exit points. No damage to the wiring. I am going to try the battery disconnection again and hope for the best. after that its off to the dealership.
Old Mar 2, 2010 | 01:12 AM
Bill Dearborn's Avatar
Bill Dearborn
Sounds like you did something to the Instrument Panel Speedometer circuit. The PCM sends a pulse train to the IP speedo circuit which then provides a voltage for the analog speedo needle and a digital signal that is sent to the HUD. If the HUD is working that means the PCM is getting the signal from the Vehicle Speed Sensor and is transmitting it to the IP Speedo circuitry and the Speedo Circuitry is sending a signal to the HUD. That leaves the analog needle as the only thing not working. Could be a voltage surge from the amp installation fried the output circuit for the needle.
Here is the official theory of operation for the speedo circuits from the Service Manual:
The IPC displays the vehicle speed based on the information from the vehicle speed sensor. The PCM converts the data from the vehicle speed sensor to a 4000 pulses/mile signal. The IPC uses the vehicle speed signal circuit (4000 pulses/mile) from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 km/h (0 mph) if a malfunction in the vehicle speed signal circuit (4000 pulses/mile) exists. The speedometer displays either miles or kilometers as requested by the activation of the English/metric button on the driver information center (DIC). The associated indicator (MPH or KM/H) illuminates.
HUD Speedometer
The HUD receives a signal from the IPC indicating vehicle speed in either English (mph) or metric (km/h) units.
Bill
Old Mar 2, 2010 | 06:50 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
bud, just lay down and shoot a flashlight on top of the diff, the harness runs ON TOP of the diff
you will see a nice wood screw that is shredded through the harness
I am just speculating of course
Old Mar 3, 2010 | 01:47 AM
Bill Dearborn
If that was the problem the HUD speed would be wrong as well. The sensor provides the data for both gauges. The failure has to be someplace that isn't common to both gauges.
Bill
Old Mar 6, 2010 | 10:14 AM
Bammz's Avatar
Bammz
6th Gear
Default Update
Thank you everyone who posted solutions and data for my problem.
Your never going to believe this one.
Driving back from town app. 50 miles, I was traveling down the road when the speedo suddenly clicked on and started working perfect...All by itself. After turning the car on and off a few times (after I stopped) all gauges reset as they should. I am pleased that the speedo is working again and that I did no damage to it but I am so mind boggled to what had happened.
Thanks again everyone your suggestions were great.
Old Apr 21, 2011 | 05:43 PM
Shinobi'sZ's Avatar
Shinobi'sZ
HUD Speedometer
Bill
I think this may have helped me lol, but I have another question.
I had a DVD/NAV installed. The installer did not know where the VSS was, so I asked somebody with a service manual to look it up and found it. Once I tapped into the wire coming from the PCM, my NAV started working and I can see the speed on the NAV unit in mph.
This was years ago. But now I notice that when I am decelerating the speedo needle will drop to 0 mph once I get below 40 mph. When I accelerate from 0 mph it will not register until above 35 mph. I thought maybe the VSS was bad, but I noticed that the GPS/NAV MPH is still working fine from 0-40 mph. So since it takes it's reference from the VSS the VSS must still be OK...or is it the analog needle in the Speedo?
It really reminds me of the when the old mechanical speedos would start to go out and they begin bouncing up and down. But I know there is nothing mechanical driving the speeds in the C5.
Old Apr 21, 2011 | 07:29 PM
Bill Dearborn
Does the speedometer read the correct speed once it gets off 0? As the description I posted above indicates the speedo will register 0 if it senses something wrong in the circuit from the PCM. Is the NAV unit getting its signal from the PCM or directly from the VSS before it goes to the PCM? Your speedo could be taking a crap or the signal it is receiving may be getting weak or noisy from the load the NAV unit is putting on the PCM if it is getting its signal from the PCM. If not the PCM may not be sending a good signal. If you have a HUD what is it doing? Do you have any codes registering when you read the codes using the DIC?
Bill
Old Apr 22, 2011 | 10:05 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Bill
Don't have a hud.
Yes once the speedo registers above 30 mph either accelerating or decelerating...it reads correct...and matches what is on the NAV mph.
I tapped into the VSS at the wire as it comes out of the PCM on the way to the speedo.
No codes.
Old Dec 19, 2011 | 11:13 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Bill
Bill,
Previously I was keeping the NAV unit turned off to troubleshoot whether it was interefering with the signal to the Speedo. But this weekend I pulled the wheel well panel off to the PCM and disconnected the wire from the NAV unit that I used to tap into the VSS on the PCM harness. My speedo now works fine.
Now to get my NAV unit back online. I had it hooked up to the VSS wire at the connnector, I am not sure (can't remember) if the wire on the PCM connector is the one between the VSS and the PCM or between the PCM and Speedo??
Any recommendations on this? I have a separate post on the C5 Tech section if you want to respond to that.
To speedometer wont register
