HELP -- Is there a trick to this?
Old Feb 21, 2010 | 03:52 PM
CO YGOSLOW's Avatar
CO YGOSLOW
Default HELP -- Is there a trick to this?
How do you remove the MAF from the air bridge? I can pull it out about .25 inch and spin it, but cannot get the MAF removed.
Old Feb 21, 2010 | 05:36 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
After the clamp is loosened it should just pull apart.
Old Feb 21, 2010 | 06:15 PM
rws.1's Avatar
rws.1
do you have a hair drier or a heat gun... it will help....
Mine was a real pain to get off.... just a very tight friction fit, nothing else.....
Old Feb 22, 2010 | 07:58 AM
Paul 75 L82's Avatar
Paul 75 L82
I used a big screwdriver and kind of pryed it from the side agaisnt the square notch.
To HELP -- Is there a trick to this?
