Eureeka! A no welding required short shifter made from stocker!
I decided to try my hand at making a short shifter without welding.
Since I have a MOMO **** that doesn't require threads I decided to find out if there was enough shifter shaft beneath all the OEM cover up.
I enlisted my neighbor Tom73 to do the initial cutting since he has every tool known to mankind and he is much more mechanically inclined than yours truly. :D
Basically we cut the black tube on both sides and then pulled out the interior piece (alloy colored) which has the rubber filled cylinder surrounding the shaft.
We cut the cylinder off and then were left with just the shaft.
I left the base as is and didn't cut off the rivets.
Here are some shots with the shifter installed.
I REALLY like this mod. :yesnod:
All thats left is to get a shorty shift boot. :D
[Modified by Scott97, 6:14 PM 3/8/2002]
MySea5,
No problems thus far.
It shifts really smoothly and feels great.
Removing the rubber filled cylinder has increased the notchy feel
of precision that the OEM piece acked IMO.
How much effort does it take to shift? Just asking as you have lost most fo the mechanical advantage.
Cool idea....and its free too!
Hopefully you'll be at MTI tomorrow and I can see that bad boy. Like everyone else who reads this, none of us is going to believe you can actually shift one that short - except that I know you and you would not :bs us.
Hope to see you soon.
Jim
I used the same method as Scott97 and I like the results.
[Modified by UR2SLW, 10:27 PM 3/9/2002]
http://forums.corvetteforum.com/zerothread?id=251372
How did you attach the shift ****? The existing shaft is only 10mm
[Modified by chuckster, 8:58 PM 3/8/2002]
The shifts are very positive and I get the same kind of feel.
Jim
Jim,
Thanks! I'm going to take some video first thing tomorrow so folks can actually see me shifting.
I don't think that I will be there tomorrow but you never know ;).
Is there another MTI dyno day tomorrow?
I have a MOMO **** that slides over a rubber sleeve that slips over the shifter shaft using 3 allen set screws.
The stock shaft had rubber residue left over from the mod and I left it on and it provides more surface to grip.
Jim
Jeff :cheers:
We'll have to compare notes.
BTW, I posted in car video: http://forums.corvetteforum.com/zerothread?id=253709
