Ignition Switch connectors pinout
Old Feb 22, 2010 | 11:30 PM
Osman's Avatar
Osman
Default Ignition Switch connectors pinout
i searched but just couldn't find it.
Does anyone have pinout specifications on connectors that connect to ignition switch ???
thanks
Old Feb 23, 2010 | 12:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ignition switch is spread out thru out the Service manual. What specifically do you need?? I can find that!
BC
Old Feb 23, 2010 | 12:32 AM
Osman's Avatar
Osman
looks like there is two connectors that attach to bottom of ignition switch.. i was hoping to get a picture that shows which wire is what... something like this..
Old Feb 23, 2010 | 10:25 PM
byronhunter's Avatar
byronhunter
C1
Connector Part Information
12110075
6-Way F Metri-Pack Mixed Series (NAT)
Pin
Wire Color
Circuit No.
Function
A
RED
1442
Battery Positive Voltage
B
YEL
5
Crank Voltage
C
ORN
300
Ignition 3 Voltage
D
LT GRN/BLK
80
Key In Ignition Switch Signal
E
Not Used
F
Not Used
C2
12162229
6-Way F Metri-Pack Mixed Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
RED
1542
B
PNK
3
Ignition 1 Voltage
C
BRN
4
Accessory Voltage
D
TAN
159
Key Out Ignition Switch Signal
E
BLK
150
Ground
F
Not Used
C3
12047781
3-Way F Metri Pack 150 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
PPL/WHT
1074
Ignition Key Resistor Low Reference
B
WHT/BLK
1073
Igntion Key Resistor Signal
C
Not Used
Old Feb 24, 2010 | 10:05 AM
Osman's Avatar
Osman
perfect.. thats what i needed...
thanks
To Ignition Switch connectors pinout
