my car is alive again!!!!
Old Feb 25, 2010 | 11:42 AM
stevejohn01's Avatar
stevejohn01
Cruising
Default my car is alive again!!!!
thanks for all the help guys
The problem was the relays on the circuit board in the metal box in the passenger foot well, i guess someone knows what that´s called coz i have no idea! It was bone dry but had some tell tell signs of water entry in the past, does anyone know where i can buy these relays? there are two....
cheers guys
SJ
Old Feb 25, 2010 | 12:57 PM
Bill Vett's Avatar
Bill Vett
Great news Steve, you can check with Gene at
Home Of The Corvette Parts And GM Parts Specialist
Please Visit GM Parts House Online or Call 484.949.2099.
See if he ships overseas. Now back to your problem you "had". You need to check the udders/ utters. Do a search to find directions on how to "milk" them clean. You also need to check the condenser drain tube to make sure it is draining properly in the summer when the air is on. If it's blocked you'll get water on the silver box again. If you don't correct the water problem it will reoccur and you'll be back with the same problem.
Old Feb 25, 2010 | 07:43 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
cheers guys
SJ
The metal box is called the BCM (Body Control Module), needs to be replaced and programmed by a dealer.
To my car is alive again!!!!
