Parts Gurus....
Old Feb 27, 2010 | 12:22 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Parts Gurus....
I'm looking for the bushing pieces that hold the shifter box.
It does not appear that they are available separately. Anyone know of a source?
Parts manual exploded view:
Old Feb 27, 2010 | 02:10 PM
ZZOOM06's Avatar
ZZOOM06
Lot's of luck with that one Bro! I wound up buying a new B&M Sport shifter just to get the bushings from the kit. For some reason my '03 Z came with the rubber wrapped bushings instead of the solid ones and they got chewed up beyond repair. I just about begged B&M
to sell me just the bushings with no luck.
Maybe someone here who has installed an early C6Z shifter will want to get rid of the solid bushings and will respond to this thread.
Good Luck!
Jimbo
Old Feb 27, 2010 | 02:22 PM
Blue 92's Avatar
Blue 92
The Hurst did not come with replacements and the originals are pretty much useless.
May have to try a WTB in the parts section.
Good Luck!
Jimbo
Old Feb 27, 2010 | 02:25 PM
TEXHAWK0's Avatar
TEXHAWK0
If you have access to a local machine shop, just have them make a set of solid bushings like on the Z06 box.
Old Feb 27, 2010 | 03:29 PM
jpandes's Avatar
jpandes
Would these stop the shifter rattle noise from my B&Mripper?
Old Feb 27, 2010 | 03:59 PM
LoneStarFRC's Avatar
LoneStarFRC
That's what I was thinking. Maybe use Delrin. Polyurethane would probably work well too.
Old Feb 27, 2010 | 05:34 PM
Blue 92's Avatar
Blue 92
I think the OEM are polyurethane. I'd say after 4 or 5 shifter changes and 80+K miles they are dead. I should have replaced them last time.
Old Feb 27, 2010 | 06:02 PM
LoneStarFRC
Seems like mine are rubber. Been a while since I last fooled with them but I remember the thin line of (cracked) rubber running all the way around the outside edge of the big oval washers. I think poly would be good since it has a higher durometer than rubber and yet not be solid like steel. Sorta like anti-roll bar bushings.
I checked my parts listings and they are not shown to be available as a separate item. Wonder if we could talk Dave68 into coming up with something. His company is Conceptual Polymer out in San Diego. Hmmm.
Old Feb 27, 2010 | 08:09 PM
ZZOOM06's Avatar
ZZOOM06
The rubber isolated bushings, (non-Z06) will stop the rattle. If you were to change your shifter to the B&M sport shifter the shaft is rubber isolated like the stock shifter and it will be quiet again no matter what bushings you are using on the shifter box mount.
Jimbo
Old Feb 28, 2010 | 02:35 PM
K RIPPER's Avatar
K RIPPER
Default make bushings
you can make bushings yourself quite easily start with a brass fitting I use pipe reducer fittings.. jam something into the center hole so it can be chucked up in a drill press or hand drill i like to use a piece of allen key as it has ridges which grip the piece once checked up run drill and work with a file,when you get close to final O.D.a small taper on one endwill tell you when you are close to final size by trial fitment and it allows you to make an interference fit... final.. drill out center to correct size drill bits are avail in sizes of 64 thou so the right center size is no prob.should take no more than ten min. per bushing if making shifter bushings the pipe reducer bushing can be cut in half to make two bushings.I have made hundreds of these over the years for throttle ,shifters and whatever and its really quite easy if using a hand drill its good idea to secure drill in a vise or clamp to a table.good luck!!
Old Feb 28, 2010 | 04:07 PM
LoneStarFRC
The problem here as I see it, is that the bushings are not round, they are basically an oval. Approx. 5/8" x 7/8" (rough guess) It's the odd shape that makes doing something at home more challenging.
Old May 19, 2010 | 12:03 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Contact me if you would like replacement rubber bushings. Although they are not the oblong shape, they fit and work well as replacements for the OEM bushings.
Here are some photos of how they look installed.
Old May 19, 2010 | 11:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MEZ will fix you up!
Old May 25, 2010 | 09:36 AM
Mez's Avatar
Mez
Thanks, Bill.
I received a lot of interest from the C5 and C6 camp. All the new bushings ship them all the same day.
If you need new bushings, please contact me.
To Parts Gurus....
