How Do I Program My Remote?
Old Mar 1, 2010 | 09:30 PM
TonyVette396's Avatar
TonyVette396
Default How Do I Program My Remote?
Can somebody point me to a link or give me instructions on how to program a keyless remote for my 99 vert?
Thanks!
Old Mar 1, 2010 | 09:32 PM
lucky131969's Avatar
lucky131969
Thanks!
How about your owners manual?
Old Mar 1, 2010 | 09:42 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
This is from the sticky in C5 General. Hope it's what you're looking for.
http://forums.corvetteforum.com/c5-g...ngths-etc.html
Originally Posted by vette747
Fob programming
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this step for each transmitter.
Old Mar 2, 2010 | 07:57 AM
TonyVette396
Thanks for the help, dadvan99. No thanks for you, lucky, unless you were willing to send me your owners manual.
Old Mar 2, 2010 | 08:22 AM
lucky131969
I'm not a mind reader....if you don't have an owners manual...state that up front. Had I known, I would have attached a link for a free download:
http://www.gmpartshouse.com/download...99corvette.pdf
Old Mar 2, 2010 | 12:04 PM
TonyVette396
Now I'll say thanks, lucky131969! I appreciate the link!
Old Mar 2, 2010 | 12:33 PM
AntonioZ06's Avatar
AntonioZ06
sort of on subject. I have only 1 key/fob when I bought the car a year and a half ago. I'd like to buy another key/fob. Now in the instructions it says turn the radio off, however I've since gone aftermarket. Will it still work? I know in the OBDII menu when it gets to the radio section it say No Communication.
Anyone try this with an aftermarket head unit? I did not use a harness adapter since I ran new wiring to bypass the stock Bose Stuff since I was taking the bose stuff out too.
To How Do I Program My Remote?
