Melrose Headers
Old Mar 2, 2010 | 08:23 AM
napoleonvette's Avatar
napoleonvette
Default Melrose Headers
Any comments on Melrose headers as far as quality and fit?
Old Mar 2, 2010 | 09:30 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I have had them on my car since July of '08. The fit and finish is excellent. I did a lot of reading in here about the various brands and what I really liked about the Melrose was they are TRULY bolt on. No need to cut the tunnel plate for O2 sensor clearance, no need for harness adapters, nothing. Just bolt them on and go. Their complete system with Random Tech high flow cats uses both the front and rear O2's and even though I did eventually have the rears tuned out, I never got a code running them. The coating still looks brand new and my car is a daily driver that sits outside year round two blocks from the Gulf of Mexico!
Old Mar 2, 2010 | 10:46 AM
Stomp'N'Go's Avatar
Stomp'N'Go
I've heard good things about Melrose, Last time I checked they only came in 1 3/4 and I need a 1 7/8 setup..
Old Mar 2, 2010 | 12:05 PM
JVetthead's Avatar
JVetthead
I have had them on my track car for about 6 yrs.. Good fit and finish is ok, I live 100' from Galveston bay so it is a bit moist around here and they are just starting to show a bit of rust but that is to be expected around here.. Inland I am sure you will not have that problem..
Other than that...
Old Mar 2, 2010 | 12:22 PM
napoleonvette
Many Thanks
Old Mar 2, 2010 | 10:28 PM
iced98lx's Avatar
iced98lx
Enjoyed them on my 98 till I sold it, nice header setup
Old Mar 3, 2010 | 11:50 AM
The Wrench's Avatar
The Wrench
There's a well-known Chevy guru who writes books and magazine articles, named Dave Emanuel. He published several results on Melrose Corvette installations, and he seems totally sold on them.
They are coated mild steel, not stainless; many debates on the pros/cons of each material.
DG
Old Mar 3, 2010 | 02:11 PM
Mark C5's Avatar
Mark C5
DG
Actually they are double coated. They're made of aluminized steel and they are ceramic coated. I have found the coating to be extremely durable.
Old Mar 4, 2010 | 09:28 AM
napoleonvette
I have had a set of coated headers on another vehicle of mine over 10 years no rust no problem , may be better than some stainless systems
Old Mar 4, 2010 | 03:03 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I've never owned a set, but I've seen one installed on a supercharged '02.
They looked good both from the top and from underneath the car. Nice workmanship... built in the USA.
Old Mar 9, 2010 | 09:27 AM
SouthernSon's Avatar
SouthernSon
The epa crap vent tube will crack at the weld on the header over time so do yourself a favor before install, either put another bead or two of weld around it or grind it off and weld it up. Otherwise, the headers are a work of art and will improve performance as well as any out there.
Old Mar 9, 2010 | 03:33 PM
j84buick's Avatar
j84buick
Bougth them on a recommendation of the shop that did my install. They look great and still look perfect a year later. No codes and no issues.
To Melrose Headers
