New C5 Owner - Computer Code History ??'s
Old Mar 3, 2010 | 07:52 PM
Advancetec's Avatar
Advancetec
Default New C5 Owner - Computer Code History ??'s
Not to long ago I picked up a 1998 C5 Coupe with 65k miles.
The car runs great except for the faulty fuel gauge droping to E occasionally. I am running Techron through it now in hopes to fix that.
I came across how to read the computer codes through the DIC.
All the codes were History codes but would like to know if I should be concerned by any of the past codes.
10-PCM
P1431H - Fuel Level Sensor 2 Circuit Performance (Cause of Gas Gauge issue??)
60-IPC
U1176H - Loss of Communication with RFA
U1040H - Loss of Communication with TCS
U1016H - Loss of Communication with PCM
A1-RDCM
B2253H - Key cylinder switch fault
B2265H - Horizontal Position Sensor Fault
B2283H - Battery 1 Fault
B2285H - Battery 2 Fault
U1064H - Loss of Communications with BCM
A0-LDCM
B2282H - Battery 1 Fault
B2284H - Battery 2 Fault
Thanks for any help!
I am mostly concerned if something seems out of the ordinary for that year car and mileage.
Old Mar 3, 2010 | 08:05 PM
SebringSixSpeed's Avatar
SebringSixSpeed
C5's were the years 1997-2004
Old Mar 3, 2010 | 08:07 PM
Advancetec's Avatar
Advancetec
My bad....Typo LOL
Old Mar 3, 2010 | 08:18 PM
SebringSixSpeed
You don't really need to worry about any H codes unless you are looking for clues to diagnose a current problem. You may as well delete them if there are no issues.
Old Mar 3, 2010 | 08:21 PM
postwhore's Avatar
postwhore
clear them and see if they re-occur , but the loss of communication codes are so common I don't think you need to worry about them
Old Mar 3, 2010 | 10:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Comms codes can be caused a LOW Charged battery. If the car was not driven recently and the battery was LOW, that could have caused the problems during the start sequence. Just clear them and see if any return.
BC
To New C5 Owner - Computer Code History ??'s
