How to remove radiator cover
OK, I seem to be search challenged and can't find anything.
Anyone know how to remove the radiator cover?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres two 10mm screws on each side of the cover. Remove the airfilter/air bridge assy, MAF wiring harness and the four screw and off it comes.
BC
BC
Received 3,812 Likes
St. Jude Donor '03-'04
There are to plastic pressure nuts or whatever they are called about mid way down. Once you remove them they are toast so just pull them out. Also there are 4 10 mm bolts on the bottom in the corner two are on the side, and two are on the bottom. The two on the side are right behind the center rubber air dam. You also need to disconnect the light and the temp sensor. both are on the lower right side of the cover.
Good luck
Good luck
