HELP!! No throttle response after FAST install
Old Mar 3, 2010 | 10:29 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Default HELP!! No throttle response after FAST install
Ok car starts rev to 2000rpms( by it self) and no throttle response. Here are the codes
P1120 TPS 1 Circuit
P1220 TPS 2 Circuit
P1516 TAC Position Performmance
Is it because it doesnt know what to do with the FAST and 90mm tb on it or what?
What can I do if anything?
Old Mar 3, 2010 | 10:39 PM
lucky131969's Avatar
lucky131969
P1120 TPS 1 Circuit
P1220 TPS 2 Circuit
Are you using an adapter for the factory wiring to the 90mm TB? If so, the adapters have been known to be wired wrong.
Old Mar 3, 2010 | 10:42 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You have no throttle response because the car goes into Reduced Power mode when the P1516 is set.
I'd say you have some connection issues with the new TB. The TPS (throttle position sensor on the TB) errors seem to confirm that. What TB are you using and harness adapter (if not using a billet TB)?
Old Mar 3, 2010 | 10:45 PM
0331MARINE's Avatar
0331MARINE
Im using a TPIS 90mm TB so no adapter. The TPS sensor is brand new. It revs to 2k by itself. I can push the gas and I get nothing.
Old Mar 3, 2010 | 11:00 PM
lucky131969
Sorry for asking, but did you follow the instructions for transferring the motor and TPS to the new TB?
Old Mar 3, 2010 | 11:01 PM
0331MARINE's Avatar
0331MARINE
It was already put on when I got it. But then again it is a used TB
Old Mar 3, 2010 | 11:07 PM
lucky131969
Ok, just in case:
Old Mar 3, 2010 | 11:10 PM
lucky131969
0331MARINE's Avatar
0331MARINE
Ill be right back. Im going to go take it off and check it.
Old Mar 3, 2010 | 11:34 PM
0331MARINE's Avatar
0331MARINE
Took it off. It all looks good. Put it back together and still does it......
Old Mar 3, 2010 | 11:42 PM
lucky131969
PM sent.
Old Mar 4, 2010 | 11:32 AM
zeevette's Avatar
zeevette
Could you have cracked the bottom part of the manifold, installing it over factory valley cover bolts?
Old Mar 4, 2010 | 01:30 PM
WKMCD's Avatar
WKMCD
Sounds like you have an air leak for a start. The car shouldn't idle at 2k - obviously.
Old Mar 4, 2010 | 03:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Originally Posted by WKMCD
Sounds like you have an air leak for a start. The car shouldn't idle at 2k obviously.
That high of idle flare at startup is a very typical result when bolting on a FAST and 90mm TB without tuning for it.
And he won't be able to even get to the tuning until he solves his throttle position sensor issue and stays out of REP mode.
An air leak doesn't cause failure of two separate TPS circuits.
Old Mar 4, 2010 | 06:36 PM
0331MARINE's Avatar
0331MARINE
Not over stock bolts.
Im going to put the old TPS on and see what happens.
Old Mar 4, 2010 | 07:03 PM
0331MARINE's Avatar
0331MARINE
Could the motor be bad on the TB?
Old Mar 4, 2010 | 07:42 PM
lucky131969
Aren't you just transferring your old motor to the new TB? Also, did you check the index of the TPS per the instructions?
To HELP!! No throttle response after FAST install
Old Mar 4, 2010 | 07:47 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
pull each of your electrical connection you undid installing your fast specificall to your throttle body. Take a long, slow look at your male and female connections, and look at a bend male end going into a female, or a bend in female.
Striaghten out the male connection, slowly and gentlly reconnection the electrical connection and clear codes.
You'll be good to go
Old Mar 4, 2010 | 08:10 PM
0331MARINE's Avatar
0331MARINE
No the TB cam with the motor and a TPS
Old Mar 4, 2010 | 08:11 PM
lucky131969
I see.....well that changes things a bit.....condition unknown....
