help plz-Idling problem
Old Mar 4, 2010 | 11:28 AM
ocpman's Avatar
ocpman
6th Gear
Default help plz-Idling problem
I'm working on a 2004 Z06. I just replaced the lifters, and when I drive the car, and come to a stop. It will sometimes stall out. It has a healthy cam long tube headers, and no cats, over size throtle body. Don't know any of the specs. Bank 2 is running rich, and posible has bad o2 sensors. I cleaned the throtle body and did a idle relearn but no luck yet. Any sugestions
Old Mar 4, 2010 | 12:12 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Is that all you replaced? the lifters?
You removed the intake, the heads, replaced the lifters.
same lifters?? or aftermarket?
Old Mar 4, 2010 | 12:13 PM
ocpman's Avatar
ocpman
6th Gear
after market comp cams, yes thats all I replaced
Old Mar 4, 2010 | 12:14 PM
ocpman's Avatar
ocpman
6th Gear
and gaskets and head bolts.
Old Mar 4, 2010 | 12:16 PM
pmj341's Avatar
pmj341
did you do the cam at the same time?
Old Mar 4, 2010 | 12:20 PM
pmj341's Avatar
pmj341
could you have a leak? or did you forget to plug in a map or maf ?
Old Mar 4, 2010 | 12:28 PM
ocpman's Avatar
ocpman
6th Gear
I double checked for leakes, and the Maf is pluged in. No the cam was in it already.
Old Mar 4, 2010 | 12:34 PM
pmj341's Avatar
pmj341
why did you change the lifters??
were the old ones noisy??
Old Mar 4, 2010 | 12:40 PM
ocpman's Avatar
ocpman
6th Gear
yes, and the noise is gone now.
Old Mar 4, 2010 | 12:41 PM
pmj341's Avatar
pmj341
did you check pushrod lenght?
Old Mar 4, 2010 | 12:45 PM
ocpman's Avatar
ocpman
6th Gear
No, Do you think the comp lifter are diferent than the stock lifters, and might need a different length push rod.
Old Mar 4, 2010 | 01:45 PM
pmj341's Avatar
pmj341
I would find out, call Comp and speak to a tech.
the only other thing is a leak in the intake track.
To help plz-Idling problem
