Sometime, my gearbox doesn't shift
Old Mar 5, 2010 | 02:26 PM
BossV8's Avatar
BossV8
Default Sometime, my gearbox doesn't shift
It seems I have a problem with my gear box. Sometimes, When I floor my foot, my gear box will go up to the rev limit and not shift. It never happened with a 85% trottle or less.
I made some test a few hours ago and could have this default several time. I then stopped the car for 2 minutes and was not able to so it again. I don't know if it is a coincidence.
I had my gearbox fluid partially changed a few weeks ago so I thought it could be that. But I had my oil level checked and it is okay (oils leaks as soon as you unscrew the plug).
Any idea? Any test protocol to suggest?
I am a bit lost!
Old Mar 6, 2010 | 06:28 PM
BossV8's Avatar
BossV8
One answer maybe they used the wrong filter : the white one instead of the black one. Does that make sense to you?
