To Clean Blackwing Filter?
Old Mar 10, 2002 | 04:06 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default To Clean Blackwing Filter?
Other tham a little soap and water, do I need to spray it with anything like a K&N?
Old Mar 10, 2002 | 09:08 AM
BLKBLUR's Avatar
BLKBLUR
Default Re: To Clean Blackwing Filter? (TexCorvette)
Tex--
According to the instructions, after it is dry, you should oil the filter as you would a K&N.
Question for others--I have a K&N cleaning kit. Since these filters are similar, can the K&N kit be used on a Blackwing?? :crazy:
Old Mar 10, 2002 | 09:31 AM
luvinc5's Avatar
luvinc5
Click on the link for cleaning instructions.
http://temp.corvetteforum.net/c5/luvinc5/donaldson.jpg
Considering the cost of the Blackwing unit, spending a few bucks on getting the manufacturer's cleaning products maybe well worth your time.
Old Mar 10, 2002 | 10:34 AM
rhoeven's Avatar
rhoeven
SLP carries the Donaldson cleaning/oiling kit. http://www.slponline.com/view_produc...RTNUMBER=25015
Roger
Old Mar 10, 2002 | 08:38 PM
JohnS's Avatar
JohnS
There is a Donaldson made cleaner and oil package. If you don't want to use it, you can use Simple Green to clean and mineral oil to re-oil. Use low pressure water hose from the inside of the filter out to flush cleaner. Don't make the mistake I did when re-oiling, it doesn't take much! Mine dripped oil for weeks after.
JohnS
Old Mar 10, 2002 | 09:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: To Clean Blackwing Filter? (JohnS)
Good advice. Also don't forget: Don't use a blow dryer or any other type of heat to speed up the drying time after washing. It must air dry only. :D
JohnS
To To Clean Blackwing Filter?
