Wix 51522 Oil Filter
Old Mar 5, 2010 | 04:24 PM
navyseal3's Avatar
navyseal3
Default Wix 51522 Oil Filter
Thot I would give this longer filter a try for my 02.Anyone have any problems associated with it.It seems to be about an inch longer than the standard# 51042.
thanks
ns3
Old Mar 5, 2010 | 04:35 PM
lucky131969's Avatar
lucky131969
thanks
ns3
So you are purposely using an oil filter that protrudes below the oil pan?
Old Mar 5, 2010 | 04:41 PM
postwhore's Avatar
postwhore
not a good move at all
Old Mar 5, 2010 | 05:12 PM
hattitude's Avatar
hattitude
I wouldn't use it for that reason.........
I remember a post a while back, about a guy using one of the filters with the "NUT" formed into the bottom of the filter canister for easy removal. He was complaining about hitting it on something......
Old Mar 5, 2010 | 06:56 PM
kingrobby25's Avatar
kingrobby25
Factory size filter works fine, do you seriously want one of the lowest things on your car to be the oil filter? Is it going to give more protection for the engine when it gets ripped off by some road debris you hit??
Old Mar 5, 2010 | 08:48 PM
TEXHAWK0's Avatar
TEXHAWK0
If you change your oil filter everytime you change the oil, the extra filter capacity is not going to help you much.
Old Mar 6, 2010 | 01:27 AM
kg54trains's Avatar
kg54trains
thanks
ns3
If it is their regular Wix inventory item for a c5 it works great. Testing of this filter have had good results without the price associated with a premium oil filter. I buy mine at napa stores and it looks similiar to the oem item but the mfg is a upgrade over that oem filter.
Old Mar 6, 2010 | 06:06 AM
dieseldave56's Avatar
dieseldave56
Default Fleetguard
I use either the PF44/46 (or Fleetguard's LF16104 ( Fleetguard's next upgrade lube filter . Largest OD 3.05", 4.58" Tall, 13/16-16 thread, ADBV). It is aproxx one (1) inch taller than the Delco PF 44/46 filter. I use Fleetguard products for my Cummins 8.3 .
To Wix 51522 Oil Filter
