Need some front lowering help!
Old Mar 6, 2010 | 02:47 AM
jwil's Avatar
jwil
Default Need some front lowering help!
I've been trying to lower the front for the past few days. I can't get the driver side bolt to budge. I have soaked the bolt area with WD-40 and then PB Blaster, I've jacked up the spring to relieve pressure and the bushing is not sticking, loosened the bottom shock bolts to get more room, and made sure I was turning the right way (counter clockwise) all I've managed to do is strip the top. I've read numerous threads, and I'm down to trying two things: 1. use 2 M14x20 bolts and try to wrench it off, and/or drop the a arm and either turn the bolt or cut the bottom of the bushing. Would someone tell me how to do this (drop the a-arm)? I haven't tried the passenger side yet, but I suspect I may run into the same problem. I don't want to lower it very much, maybe 1/2 inch. Thanks for any help you can give me.
Old Mar 6, 2010 | 07:00 AM
IRON MAIDEN's Avatar
IRON MAIDEN
Take out the 4 bolts to the upper A arm and it should give you enough room to work. You can pull the shock out this way too if you need the extra room to work. I just did this in order to remove the front bolts.
P.S. When removing the 4 upper bolts, pay close attention to the washers so they can be put back in the same way.
