Warning lights back on again
Old Mar 7, 2010 | 12:19 AM
boterre2471's Avatar
boterre2471
Default Warning lights back on again
Last week I asked for help inreference to all of the warning lighting up like a christmas tree. Someone said the battery was bad. Sure enough I brought the car back to the battery store and it was bad. It was changed last Saturday. While driving my vette today, I ran across a speed bump, and all the warning lit up again, including all the gages and the radio went off like no power was feeding it. If you turned the ignition switch off and back on everything came back to life. A short while later the same thing happened again. It's almost like I am losing a ground or something. Any ideas would be greatly appreciated.
Old Mar 7, 2010 | 12:12 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check those battery connections and the crimps on the cables themselves, then do the same things at the starter solenoid which is where all the power comes together. Do not forget that its electrically hot down there. Its also very possible your iginition switch might be having issues to. Bill Curlee as an excellent write-up on repairing it in the sticky.
Old Mar 7, 2010 | 01:11 PM
Melsy's Avatar
Melsy
It's not impossible to get a bad battery. That said, I would almost bet on your battery terminal connections. Let us know what you find.
Old Mar 7, 2010 | 09:56 PM
boterre2471
Went to Auto Zone and the battery is good, cleaned all the grounds, battery connections etc. Car is still showing the same codes. Checked the connections on the BCM and they were good. The BCM is not damp, Loss for words.
Old Mar 7, 2010 | 10:00 PM
lucky131969's Avatar
lucky131969
Not posting codes tells us nothing. Based on your symptoms, it could possibly be the ignition switch...or wiring in the left according tube.
Old Mar 7, 2010 | 10:05 PM
lucky131969
oohhkay.....two threads on this now?
Old Mar 7, 2010 | 10:15 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
It happened twice?
To Warning lights back on again
