Uhm, what do you mean "some"? ALL C5's with base model C6 wheels need a spacer at the rear to make it look flush with the body, otherwise, it will not look right...
I mean "some" tires rub on the inner wheel well, and "some" don't. Sure, I know they look better with spacers, than without spacers, BUT, it would take about 3/8" spacers to make to make it look "proper." Thank You
You say not half bad, So that means it does make the ride a little rougher?
Spacers are a definite then if I want the rim to be flush with the body?
It is a much better ride than the C5 OE tires and closer to non run flat ride. Its acceptable for long distances too.
yes, use a spacer so the rear wheel is more flush with the outside of the wheel well.
Here a pic.. If I were to do it again I would have gone a little thicker on the rear spacer. Since I already have longer studs installed all the way around it would have been easy to do.
Car looks great with those wheels!
Are those chrome or polished aluminum?
I originally was going to order the C6 style wheels from house of wheels in chrome, in the original 17" and 18" sizes. I could also reuse my tires if I did that.
I found someone local who has original factory C6 aluminum polished wheels off a 2006 in mint condition for about $675 and they are 18" and 19".
So my questions are do you think these are worth getting over the chrome reproductions?
How does the Aluminum Polished hold up or they clear coated from the factoryu? Do they look almost as good as chrome?
Is it worth going with the bigger wheels since I will have to invest in new tires as well and spacers?
And advice would be appreciated. I never bought wheels before and I don't know to much about the finishes.
Thanks!
Those wheels are the factory polished with a clear coat. They will look great for a long time if you leave them like that. They are not as shiney as chrome or a high polished aluminum wheel without the clearcoat. I had the Z51 tires at that time the pic was taken and those tires actually rode nice for new tires.
