ABS, Traction Control DTC 1218
Old Mar 9, 2010 | 08:07 AM
Nickkz06's Avatar
Nickkz06
Default ABS, Traction Control DTC 1218
I can't seem to solve a DTC 1218 in my 03 Z06. I had my EBCM just rebuilt by absfixer. Could the BPMV be shot? Any special ground locations to check? Any input would help!
Old Mar 9, 2010 | 06:27 PM
trussme's Avatar
trussme
Default 1218??
I can't find code PO- or C- 1218 in the code listings for a 2003?? are you sure it is 1218?
Old Mar 9, 2010 | 06:53 PM
lucky131969's Avatar
lucky131969
It's in my 2003 service manual.
Old Mar 9, 2010 | 06:55 PM
lucky131969
Have you done any troubleshooting with the service manual ?
Old Mar 10, 2010 | 02:04 PM
trussme's Avatar
trussme
thanx! the code lists I have do not show it...what is the cause?
Old Mar 10, 2010 | 02:17 PM
lucky131969
Old Mar 10, 2010 | 05:01 PM
trussme's Avatar
trussme
Default Thanks..Lucky131969
looks like Nickkz06 has his answer and I will update my codes list..
Thanx again! Bill Trussell
Old Mar 11, 2010 | 07:30 AM
Nickkz06's Avatar
Nickkz06
Thanks for your help
Old Mar 12, 2010 | 05:15 AM
TexCzechVette's Avatar
TexCzechVette
Did this work for you - ? I am seeing the same problem on my 2003. Let me know, OK? Thanks
Old Mar 12, 2010 | 05:50 AM
TexCzechVette
Nick,
Check this link - I just cleared my 1218 by cleaning the post and ground here.
http://forums.corvetteforum.com/c5-t...tion-long.html
To ABS, Traction Control DTC 1218
