What sensor is this?
Old Mar 11, 2010 | 06:59 PM
enigma94's Avatar
enigma94
Default What sensor is this?
I saw I was leaking some fluid at the rear end, and it looks to be coming out of this sensor (see below pic). What sensor is this? Is it common to leak/come loose? I changed the tranny fruild and diff fluid probably 10,000 miles ago and it hadnt leaked before that.
Pics:
(the one to the top left in the first pic)
Old Mar 11, 2010 | 07:21 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Transmission fluid temperature sensor.
Old Mar 11, 2010 | 07:25 PM
lucky131969's Avatar
lucky131969
I disagree
Old Mar 11, 2010 | 07:46 PM
enigma94's Avatar
enigma94
soooo anybody? Is it even a sensor? It doesnt have a plug going into it at all. Also if somebody could tell me the size it is? I cant seem to get a wrench big enough in there without having to take off the axle back but it seems like it could be a 1 5/16''? I need to know so i can buy a deep socket to try and tighten it.
Old Mar 11, 2010 | 07:57 PM
Russ K's Avatar
Russ K
That is the 1-4 skip shift solenoid, not sure what size deep socket is needed.
Russ Kemp
Old Mar 11, 2010 | 07:59 PM
enigma94's Avatar
enigma94
Russ Kemp
Ahhhh Thank you sir! I didnt want to mess with it till I knew what it was. Now if somebody can tell me what size it is i'll be all set!
Old Mar 12, 2010 | 07:33 AM
Quicksilver Vert 01
Russ Kemp
Well, I stand corrected. :o
Thanks Russ!
To What sensor is this?
