Standard to auto conversion! suggestions????
Mar 15, 2010 | 01:07 AM
I am looking at swapping my 6 speed standard for a auto that can handle 1200 rwhp i am looking for suggestions and people that have done this. This conversion will be getting done on a 2003 c5 z06.
Thanks guy's
Mar 15, 2010 | 01:38 AM
rpmtransmissions.com
Send it there and have it done turn key, or they can send a kit. 1200rwhp is a tall order.
Mar 15, 2010 | 03:00 AM
Quote:
Originally Posted by
Chris Stewart
Good advice.
Mar 15, 2010 | 07:32 PM
Mar 15, 2010 | 10:36 PM
I think you're talking 4L80E or a transmission like a full race Powerglide to pull that off. 1200hp is huge if you hook up and still a lot even if you don't. I'd also suggest you find a swap that will use the C6 rear-end for that power level - it's heavier and every bit helps.
Not sure what you're doing with the car but maybe a straight axle swap is in your future.
Peter
Mar 15, 2010 | 10:42 PM
I am running the stage 4 dte rear end and a built rpm standard transmission right now and just want to switch to an auto
Mar 16, 2010 | 03:49 AM
St. Jude Donor '08
Tysonh
Not sure what your experience is corvette's but independent suspension is not drag race friendly, it squats and you loose traction, etc ...
1200 rwhp is a lot of power. Your current differential ain't going to make it. You'll need a Zr1 differential.
Mar 16, 2010 | 02:28 PM
i talked to dte and they said the diff i got will hold up to around 1400hp unless theres some bad wheel hop
Mar 16, 2010 | 03:00 PM
I though I read somewhere about someone doing a Ford 9" rearend and ditching the IRS for drag racing.
