tail light wiring harness question (gounding block?)
Old Mar 16, 2010 | 11:40 AM
Cobraboy's Avatar
Cobraboy
Default tail light wiring harness question (gounding block?)
I'm going to use a C5 tail light wiring harness, and the lights, on a different car that I'm modifying. I've got the lights and the harness. There is one black wire in the harness, that I will assume is a ground. This seemed a bit strange to me that it would only use one ground lead, and a fairly thin one at that, for powering up to 10 bulbs. My main question is about the connector thing in the middle of the harness. This is a rectangular block with many black wires going into it (that I would assume are the indivudual ground wires from each bulb). The strange thing is that this connector thing is capped of, so it doesn't look like it actually connects with anything. Can anyone tell me exactly what this thing is?
thanks,
Rick
this is the car that it is going in:
www.wheeltimesolutions.com/Dineroproject
Old Mar 16, 2010 | 11:54 AM
byronhunter's Avatar
byronhunter
SP400!!!!
Old Mar 16, 2010 | 12:46 PM
Cobraboy's Avatar
Cobraboy
Thank you.....I think.
Since I'm at work and can't see posted pictures (I only see the red X), I assume when I get home and check, it will mean something.
Rick
Old Mar 16, 2010 | 02:49 PM
byronhunter
Rick
It will! Enjoy.
To tail light wiring harness question (gounding block?)
