Help
Old Mar 16, 2010 | 12:51 PM
mickey_7106's Avatar
mickey_7106
Default Help
Hello all.
Yesterday while driving on the freeway (65mph) it felt like the car was holding back. more like a pulse or if i were tapping on the brakes. it got worse as i decelerated. i thought it was going to stall on me cause the rev will drop to about 400 the jump to 700. i managed to find a safe place to pull over. checked all connections under the hood and everything checked out ok. i start the car, take off and everything is fine now! WTF? i didnt get any messages on the DIC but here are the codes i pulled up
28-TCS - Traction Control System
C1225 RF Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1291 Open Brake Lamp Sw Contacts During Deccel
C1292 Set Curnt/Prev Ign Cylce
40-BCM -Body Control Module
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
B0-RFA - Remote Function Actuation
U1096 Loss of Communication with IPC
U1064 Loss of Communication with BCM
U1016 Loss of Communication with PCM
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
what could have caused this? No spark? No fuel?
car has about 105K, any insight will be helpful.
TIA
Old Mar 16, 2010 | 01:31 PM
memphis_vette's Avatar
memphis_vette
how is the battery on the car? when the batteries go bad on these cars they go crazy. also check all grounds and make sure they are all clear of corrosion and are not loose
Old Mar 16, 2010 | 01:48 PM
lucky131969's Avatar
lucky131969
Originally Posted by mickey_7106
Hello all.
TIA
Take a close look at the battery cables for corrosion/security. The C1291 code is somewhat telling, in that it's not seeing a brake pedal input on decel.....or like 12 volts was lost to the fuse. Minifuse 8 is hot at all times....straight from the battery.....so check those cables.
Old Mar 16, 2010 | 03:44 PM
mickey_7106
battery connections are good. its sooooooo dirty under my hood i didnt even bother to check for anything else. she will get a very deep cleaning this weekend
Old Mar 16, 2010 | 04:13 PM
dougbfresh's Avatar
dougbfresh
I'd look at chassis grounds 1st, read the electrical stick at the top of the section.
Also the wiring in the passenger door acordian is a KNOWN issue causing all kinds of issues like this. I think this is also covered in the electrical sticky.
Old Mar 16, 2010 | 06:46 PM
Jewjenk's Avatar
Jewjenk
Looks like, USER ERROR, a car that is well kept, will keep well the driver.
Old Mar 19, 2010 | 12:12 PM
mickey_7106
it happened again on the freeway for about 2 seconds. this time Check engine light came on.
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
time for a new MAF?
Old Mar 21, 2010 | 08:33 PM
mickey_7106
well i think i know what was wrong with my car. at first i thought it was the wires from where it plugs in.. but then i found out it was worst. does any one have a PN for that?
Old Mar 22, 2010 | 03:09 PM
mickey_7106
i think i found the AC delco P#. can someone confirm this is the right one before i buy? thanks
CONNECTOR-W/LEADS, 3-WAY F. *BLACK
Part Number: PT1604
Product Notes:
[Sensor-Mass Airflow Connector]; 3-Way female black
Per Vehicle: 1; Years: 1997-2000
Old Mar 22, 2010 | 03:15 PM
dougbfresh's Avatar
dougbfresh
Why don't you just fix what you have?
Old Mar 22, 2010 | 03:31 PM
mickey_7106
i could but im not sure how to go about fixing the wires by the plug. i want it too look as clean as possible
Old Mar 22, 2010 | 04:11 PM
dougbfresh's Avatar
dougbfresh
Splice in some new wires, shrink wrap them, then put a new protective cover on (you can get it in rolls at the auto parts stor).
Old Mar 22, 2010 | 07:35 PM
lucky131969
I'm sure you know you can purchase the chaffed wire loom at most auto parts stores. Why not by a new connector pigtail ?
http://www.lsxtune.com/shop/product_...oducts_id/1084
Old Mar 22, 2010 | 07:45 PM
mickey_7106
i will. i just needed a temp fix since this is my DD
i made it very short to prevent this from happening again
Old Mar 22, 2010 | 08:06 PM
lucky131969
I hope that is indeed a temp fix, as that length is unacceptable in my opinion....harnesses have slack for a reason.
To Help
