O2 codes from long tube headers
Old Mar 17, 2010 | 05:42 PM
jaybar's Avatar
jaybar
Default O2 codes from long tube headers
I have read all the threads on the subject and got some helpeful information. I am getting codes:
P0 135
140
155
160
I know they represent the O2 sensors the two front and two aft of the cats.
Now I don't have cats and have pluged the rear sensor bungs. I thought my tuner tuned out the rear sensors or so he said. But I am still getting all the above codes.
Now what I have learned is the positon of the sensor farther back than stock will cause problems because they don't get warm enough. I did what was recomended and bought rear senosrs and installed them in the front location and used adapters to connect them.
I have read on this forum there is some adjustment a tuner can make to the 'tables" and have the sensors work at a lower temp or come on sooner or something like that.
So that is my question what do I ask my tuner to do to make the front senosrs work?
Thanks,
Jay B
Old Mar 17, 2010 | 05:58 PM
lucky131969's Avatar
lucky131969
P0 135
140
155
160
Now what I have learned is the positon of the sensor farther back than stock will cause problems because they don't get warm enough. I did was was recomended and bought rear senosrs and installed them in the front location and used adapters to connect them.
Thanks,
Jay B
Have you checked the minifuse #15 in the underhood fuse box ?
Old Mar 17, 2010 | 07:18 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I've gotten a "slow response" code from time to time because the sensors are located further back. I don't know specifically what tables need to be modified to fix this but I turned that code off completely to resolve the issue. I would think you would want to program the sensor to come on Later to prevent the code allowing them more time to heat up. I have found over the years of owning this car that my sensors seem to last ~2 years with my current mods; then they need to be replaced because the response times tend to slow, causing problems.
Old Mar 17, 2010 | 07:53 PM
jaybar's Avatar
jaybar
Yes the fuse is ok.
Old Mar 17, 2010 | 08:45 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Its kind of weird with LT headers and codes. I drove around for a year with all the bolt ons (with cats but high flow) and never got a code.
Had you posted this two weeks ago, I could have clicked off the codes for you because I was at my parents house in Stuart.
Old Mar 17, 2010 | 08:54 PM
jaybar's Avatar
jaybar
Timing is everything! How would you have clicked them off?
Old Mar 18, 2010 | 11:32 AM
phils C5 vette
HP tuners
Old Mar 18, 2010 | 05:14 PM
jaybar's Avatar
jaybar
HP tuners
Ok, HP tuners is cool. I thought you were just saying you would clear my codes. That would last about 5 minutes till the codes come back.
So am I correct in understanding that some how( with HP tuners) the o2 sensors can be "curved" to live in the cooler environment the long tube headers provide?
I did see a post during my search where a forum member drilled holes in the tip of sensor to let in more gas, I will try anything at this point.
Old Mar 18, 2010 | 06:16 PM
phils C5 vette
your front ones shouldnt have an issue, and the rears are turned off
never heard of this
Old Mar 18, 2010 | 06:52 PM
jaybar's Avatar
jaybar
Well maybe they shouldn't but they do. Codes are PO 135,140,155,160.
The rear o2 are removed and pluged, so those codes are meaningless, my tuner should have turned them off. But the front ones are the problem. When they "code" the car goes into open loop and runs off of the fuel curves that GM put in as the default not the custom curves my tuner installed. You can feel the difference on a road course when it changes over.
I also found on LS1 tech that the slots in the o2 sesors can be enlarged with a small screw driver by prying the slots open wider. The poster said that helped.
Old Mar 20, 2010 | 01:10 PM
jaybar's Avatar
jaybar
Well, I checked the fuse again and it was blown. I answered eariler that it was ok but then again I had checked it a few months ago. So repalced the fuse still same 4 codes. Jacked it up looked around wires were not touching the headers everything looked good but did notice the ground strap from the frame to the engine on the drivers side was loose about two to three turns. I thighten it up let it run on the jacks and kept checking no codes. Took it off the jacks and went for a ride. Ran great got home and checked and got Po140 and 160. Meaning "slow respose" the 135 and 155 did not show up. So I am thinking it is caused by the sensors not getting hot enough but that is a guess. Is there a way to check the sensors like putting an ohm meter on some termanals etc???
I am running Demso sensors if that means anything. I put them in new with the headers.
Ideas??
One other question. Does the computer go into open loop only when the check engine light comes on? In other words am I still in closed loop even those I get the "slow response "codes?
Old Mar 20, 2010 | 05:39 PM
Russ K's Avatar
Russ K
P0140 & P0160 are for insufficient activity for the rear O2 sensors. You need to delete them in the tune.
Russ Kemp
Old Mar 20, 2010 | 06:01 PM
jaybar's Avatar
jaybar
Russ Kemp
Russ,
Thank you very much. I looked at these codes so often I forgot that sensor 2 is the rear. So since they have been removed, everything is cool, I just get them programed out. Wow what a relief. Now I can enjoy my new LS-6 engine which was just installed.
Old Mar 20, 2010 | 06:48 PM
lucky131969
Which end was loose...the engine side, or chassis side?
Old Mar 20, 2010 | 07:08 PM
jaybar's Avatar
jaybar
It was loose at the engine.
Old Mar 20, 2010 | 07:19 PM
lucky131969
Well, that's pretty important. That ground point is G105. It has two terminals: one being the ground strap, and one being a ground point for SP122. SP122 is the ground location for the O2 sensor(s) heater circuits, and provides a ground for the fuel pump relay, and oil level sensor.
Old Mar 21, 2010 | 11:18 AM
jaybar's Avatar
jaybar
Wasn't sure that there were two wires on the bolt so I jacked it back up
let it cool down and went under. The bolt has two leads one the ground strap the other the lead going to the wire harness for the O2 sensors.
I had assumed both leads were connected since the o2 sensors started working after I tightened the bolt, but I had to make sure. And I guess the loose connection could have caused the fuse to blow also.
Many thanks to all who offered suggustions. This forum is the greatest!!
I don't know how many of us with limited knowledge of our cars could
get along without Corvetteforum.com
To O2 codes from long tube headers
