Bellhousing removal with engine in car?
Old Mar 18, 2010 | 06:51 AM
jrmotorsports55's Avatar
jrmotorsports55
Default Bellhousing removal with engine in car?
Any tips on removing the 5 bolts (3 look easy, but the other 2 look like they will be a pain), and getting the bellhousing out? Looks like a pretty tight fit.
Thanks,
Jason
Old Mar 18, 2010 | 10:14 AM
HP_Addict's Avatar
HP_Addict
Obviously the torque tube is out of the way at this point. Get a long extension and a good swivel socket, not a swivel adapter but a socket. I think it is a 13mm. The top bolts are hard but not impossible. You can also jack up on teh fornt of the engine to buy you a little more room for reaching the bolts and squeezing teh bellhousing out.
I always remove the bellhousing when doing a clutch, I find it easier.
Old Mar 18, 2010 | 10:58 AM
MotleyDrew's Avatar
MotleyDrew
yes, you just need an extension and a good small/short pivot end, they are tricky but can be done.
Old Mar 18, 2010 | 02:01 PM
jrmotorsports55
Thanks, I appreciate the info.
Jason
Old Mar 18, 2010 | 07:45 PM
jrmotorsports55
Got it out, what a pain.
Now I need to find a machine shop to match balance my new clutch, as the old one had one weight in it.
Thanks,
Jason
Old Mar 31, 2010 | 09:31 AM
SmoothFRC's Avatar
SmoothFRC
I am at this point in my clutch install also... Havent yet tried to pull it out, but the top bolts look like a bear...
It was suggested to me to lower the front cradle a little to make it easier to get to the bolts.... I am wondering if i can just lower the rear of the motor down a bit more - as i am not that close to the firewall yet.
Old Mar 31, 2010 | 09:40 AM
lucky131969's Avatar
lucky131969
Why are you removing the bell housing just to change the clutch?
Old Mar 31, 2010 | 01:34 PM
SmoothFRC's Avatar
SmoothFRC
sounded easier to remove this, then having to deal with turning the engine over by hand to properly torque down the clutch.
Do you not believe this is the case?
Old Mar 31, 2010 | 01:41 PM
lucky131969
No, I don't. Remove the spark plugs, and the engine is easy to turn with a flywheel tool. If you don't want to dick with #7&8, then just remove 1-6. Piece of cake.
Old Apr 1, 2010 | 09:26 AM
SmoothFRC's Avatar
SmoothFRC
Figured i had a few extra days before all the parts arrived - so had some time to kill....
I did order a flywheel tool... thought this may come in handy, so i will try that method.
Thanks,
John
Old Apr 1, 2010 | 10:41 AM
lucky131969
Thanks,
John
Good time to inspect the torque tube couplers....
Old Apr 1, 2010 | 02:06 PM
jrmotorsports55
I removed the BH b/c I am installing a dual disc setup, and it seemed a lot easier this way.
Tore down my torque tube last night, and with 55,000 miles on it, the couplers were mint. Glad I bought the car from an older guy.
Jason
Old Apr 1, 2010 | 08:21 PM
SmoothFRC's Avatar
SmoothFRC
yeah, i had one that was torn up a bit and the other was fine. then again, i have been pushing some power through them for a while now...
To Bellhousing removal with engine in car?
