Clutch/shifting issues
Old Mar 18, 2010 | 09:52 PM
rr77753's Avatar
rr77753
Default Clutch/shifting issues
My 98 M6 is grinding during shifting between 2/3/4, and from 4/3, especially at the higher rpm levels. I am having some clutch slippage as well. The clutch assy to include slave cylinder/pilot bearing will be replaced in the very near future. I recently had a tune, and tuner indicated that the slave cylinder was going out, and would need a clutch replacement in the near future. I have seen no indication of fluid leaking from the car, and I have refreshed the fluid a few times within the last year, and yes it was black. Will the clutch replacement fix the grinding between the gears?
Old Mar 18, 2010 | 10:37 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
It's really hard to say but I'm thinking it's more a problem of the paper blocker rings being shot. It's a common problem with the early C5's and only a trans rebuild will fix it.
Old Mar 19, 2010 | 11:25 AM
rr77753's Avatar
rr77753
TTT.... looking for as many opinions as possible
Old Mar 19, 2010 | 01:31 PM
rr77753's Avatar
rr77753
Well, my worst fear is gaining monentum, took car to the guys at G-Force and they suspect the synchros being bad... Surgery begins on Monday
To Clutch/shifting issues
