real wheel hub replacement
Old Mar 20, 2010 | 08:14 PM
vjjack04's Avatar
vjjack04
Default real wheel hub replacement
Need to replace a rear hub...grease all over the wheel well. Anyone have tips on gettting the hub off without the factory tool? Also any recommendations?
Old Mar 20, 2010 | 08:53 PM
vjjack04's Avatar
vjjack04
also any recommendations on vendors and pricing?
Old Mar 20, 2010 | 09:13 PM
daleweible's Avatar
daleweible
If you have grease all over have you checked the outer cv shaft boot and does it have a split? dont sound like a hub. I just change my right rear last weekend for bearing noise. I had no grease all over. the only time I have had gease is a torn boot on the cv
Old Mar 20, 2010 | 09:28 PM
vjjack04's Avatar
vjjack04
could be the boot but have not found a tear. I need to get it off and am looking for info on seperating the hub from the axle (without the factory tool) - which I can buy but just looking for someone's home solution.
Old Mar 20, 2010 | 09:36 PM
BHart1360's Avatar
BHart1360
Do hubs ever wear out in low mileage cars? (Mine has 45k, 2001Z) What are the symptoms?
Old Mar 20, 2010 | 10:20 PM
daleweible's Avatar
daleweible
I also have an 2001, Mine started making noise on sharp left hand turns [right bearing] about 45000 miles, After a rear end alignment it made noise all the time. Changed the hub/bearing assembly noise gone. about a 3 hour job.
Old Mar 21, 2010 | 01:00 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
are you sure about a factory tool? I saw a thread last night on another forum where the guy said the key is to activate the parking brake several times beforehand, then the hub will come off easily once the 3 T55 bolts are removed from the backside....you will have to dissassemble part of the suspension first for clearance.
Old Mar 21, 2010 | 01:34 PM
vjjack04's Avatar
vjjack04
Thanks for getting us back on topic. I am not sure. I have the factory manuals and have disassempled the rear end before (replaced the diff) but never removed the outside of teh axles from the hub. The factory manual shows a tool that bolts to 3 lugs and has a pressure bolt threaded in the middle (like a balancer puller) - by the way a balancer puller is to small. I have not removed the torx bolts but will.....
Old Mar 21, 2010 | 02:02 PM
bumble-z's Avatar
bumble-z
Well, you may call this off topic too. To sling black/bluish grease onto the wheel wells, would only require a hard to see very small hole in the boot. Ask me how I know. After driving and then let set for a while the while the grease was still hot in the boots, the grease would drip and poole at the bottom inside barrel of the wheel.
Old Mar 21, 2010 | 02:11 PM
$$$frumnuttin'
Hey Bob, it was worth it though with those coilovers, right?
Old Mar 21, 2010 | 02:14 PM
$$$frumnuttin'
Old Mar 21, 2010 | 02:16 PM
vjjack04's Avatar
vjjack04
No, I get that. I have to remove the axle to figure out if it is the boot for sure. either way I have to get it apart. I think I have found a link that will help. Here it is for others who may be interested.
www.jakelatham.com/C5/misc/C5_Rear_Wheel_Bearing.doc
This guy did a good job of documenting....
Old Mar 21, 2010 | 02:43 PM
bumble-z's Avatar
bumble-z
VJjack04, I agree, that is a great, detailed, pictured ,"How to". I was under the impression to replace the axle nut w/ new & not re-use the old? Now, let's get to it, and fix your baby! ha. ha.
Old Mar 21, 2010 | 04:48 PM
daleweible's Avatar
daleweible
I did not use any special tool, just asd VJjack04 did, used a yok[ set on 3 lug studs] threaded in the center and pushed the axle free, it did not push hard either as I just used my hand to push it out of the hub.
Old Mar 21, 2010 | 06:13 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I left the nut on the end and whacked the damn thing with a hammer and it popped right out... No problem.
I had to remove the Hub just to replace the stupid parking brake shoe retainer clip! Stupid....
Old Mar 21, 2010 | 06:17 PM
daleweible's Avatar
daleweible
Did you used the same axle nut or a new one, I reused mine, yet read to replace it?
Old Mar 21, 2010 | 06:25 PM
tstar's Avatar
tstar
Same one, I wasn't aware it was a one time use nut. I seriously doubt there will be any ill effects from reusing the nut IMO...
Tim
To real wheel hub replacement
Old Mar 21, 2010 | 07:08 PM
$$$frumnuttin'
Tim
We tested this joint in the fastener lab when this design was developed. It was concluded the nut could be used up to 5 times before any noticeable drop in tension occurs.
Old Mar 21, 2010 | 07:15 PM
tstar's Avatar
tstar
Cool! Four more to go!
Thanx!
Tim
Old Mar 21, 2010 | 07:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I seriously doubt the bearing is bad. Theres minimul grease inside the bearing and its Pink/WHITE.
Heres a sample pic:
You have a loose or bad CV Joint boot. That grease is GREEN!
BC
