Wind noise in a vert?
Old Mar 21, 2010 | 04:01 PM
lowflyer1's Avatar
lowflyer1
Default Wind noise in a vert?
I recently bought a 2003 C5 vert and enjoy it thoroughly, except....
For the wind noise from around the door window/seals at highway speed. It's not too bad up to about 70 mph, but above that it's really a "bit much".
The other factor is outside wind. The other day I was on the freeway when there was a 30-40 mph wind blowing. It was just about impossible to hold a conversation.
Now for the question, does the window "tip-in" adjustment help in air leaks at the A pillar or at the rear of the window, or just along the top edge? I did the "dollar bill" test and the window fit is pretty good along the top, a little loose at the back edge.
Any other ideas?
Thanks, from a new guy.
Ken Edney
Chandler,AZ
Old Mar 21, 2010 | 04:16 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
get a loud exhaust, problem fixed
Old Mar 21, 2010 | 04:42 PM
STL94LT1's Avatar
STL94LT1
My 01 Vert isn't too noisy at speed. The previous owner (ScottN) ran auto weatherstip between the top and it's frame.
http://forums.corvetteforum.com/c5-t...er-speeds.html
Old Mar 25, 2010 | 05:21 PM
kettemr's Avatar
kettemr
You can adjust the window a few differnt ways... You may have to loosen the bolts that hold the brackets tight at the bottom of the window and move the window forward a bit.
Old Mar 25, 2010 | 06:28 PM
65convt's Avatar
65convt
My wifes 98 convt isn't to noisy. Still pretty tight with only 13,000 miles I guess.
You might try keeping it under 70 and don't drive on very windy days.
Wish I could suggest a cure for your noise problem.
Old Mar 25, 2010 | 07:05 PM
FRCTony's Avatar
FRCTony
Put the top down, where it belongs.
Old Mar 25, 2010 | 08:58 PM
KenShores's Avatar
KenShores
There is a post here that shows the adjustments. You need to pop the door panel off if I remember correctly.
Old Mar 25, 2010 | 09:22 PM
KenShores's Avatar
KenShores
OK i found a link, i'll try to add in here
www.theredlion.us/TipIn.htm
It looks like depending on how bad the leak is, you may not have to take the door panel off. Good luck. My 02 vert is not that noisey, it an adjustment sould help.
To Wind noise in a vert?
