traction control problem
Old Mar 12, 2002 | 12:28 AM
martin97c5's Avatar
martin97c5
Default traction control problem
anyone experience a traction control service warning on the display? i hit a hard pothole and now my check engin light is on. Costly repair? i hope not
Old Mar 12, 2002 | 11:39 AM
JMon's Avatar
JMon
Cruise-In III Veteran
Default Re: traction control problem (martin97c5)
I had the connector on the Maxi fuse get a little glazed over, not broken, just glazed on the connectors. Enough to cause the system to stop working once. Pulled the codes and the computer was full of Communication lost codes. So Figured it must be a fuse. replaced it and everything came back on-line. If your traction control and ABS lights are both on, check the Maxi fuse. If just one, try the mini fuse.
Old Mar 12, 2002 | 12:33 PM
qs01coupe's Avatar
qs01coupe
I haven't had the problem but a friend of mine had something similar happen when he went over some railroad tracks a little too fast. I think he just reset the error codes and he was fine.
Old Mar 12, 2002 | 10:18 PM
The Worm's Avatar
The Worm
Cruising
Happened to me tonight. "Service Traction Control----Reduced Engine Power" came on, and left me on the side of the road. After several minutes and a couple of engine restarts, it was OK, but Check Engine Light (MIL) was on. MIL went off after three restarts and everything back to normal. The road was wet, no wheel spin, doing about 30 MPH when it happened. Now I don't know if I should take it to a dealer and see if they can find what caused it, or just hope it doesn't happen again.
To traction control problem
