C5 Z06 Exhaust Install Question
Old Mar 22, 2010 | 09:04 PM
jost6453's Avatar
jost6453
Default C5 Z06 Exhaust Install Question
I'll soon be replacing the stock mufflers on my 2002 coupe with the titanium Z06 mufflers. How high do I need to get the rear end up in the air to have enough clearance to remove the old and install the new?? I don't have a lift ... and would like to do it myself ... but am limited by what can be accoplished with convention jacks.
Old Mar 22, 2010 | 09:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Like 32" You will need to put the front tires up on some 2X6 planks to keep the front end from touching the ground when its jacked up that high.
BE CAREFUL!
BC
Old Mar 23, 2010 | 02:48 PM
jost6453's Avatar
jost6453
Is that 32" HIGHER than it currently sits .... or do I need a total of 32" of clearance? Either way, I'm rethinking plans to do it myself. Thanks.
Old Mar 23, 2010 | 04:41 PM
postwhore's Avatar
postwhore
I saw a guy run the back end off over a loading dock to do his
just backed up so the rear wheels were right on the edge.
dock was 3' high
Old Mar 23, 2010 | 07:14 PM
hawk4077's Avatar
hawk4077
A good shop won't charge that much for this. Be smart and safe have it done right things happen to fast under a car and theres no where to go
Old Mar 23, 2010 | 07:53 PM
lucky131969's Avatar
lucky131969
My dad got his GHL's done recently for $50, and 30 minutes of his time.
Old Mar 23, 2010 | 07:59 PM
Paul 75 L82's Avatar
Paul 75 L82
I used 2 layers of 2x8's 30 " long. Screwed 2 sets of that together so now it's 16" wide x 30 " long 2 thickness of 2 x's. Put my floor jack on that and used a 4" thick wood block on top of jack, and all of that under the cross member of the rear end. Now getting the car high enough to get that set up under the cross member is another task. If you have everything already unbolted before you go up high you can just roll out the stock muffler. If you don't have the right equipment it can be dangerous.
Old Mar 23, 2010 | 11:08 PM
madman91's Avatar
madman91
dock was 3' high
lol that sounds like a smart thing to do better make sure your ebrake is adjusted right and the front wheels are chocked... alot!
Old Mar 24, 2010 | 12:56 AM
postwhore's Avatar
postwhore
actually , the car wasn't going anywhere
he didn't jack it up one bit
just backed it up , turned wrenches and was done
Old Mar 24, 2010 | 01:22 AM
madman91's Avatar
madman91
ill bet that would be much easier than lifting the car 3 ft in the air
Old Mar 24, 2010 | 02:18 AM
postwhore's Avatar
postwhore
and safer
To C5 Z06 Exhaust Install Question
